> building an auto-x / short track / street car, making some improvements
B2524
post Mar 30 2012, 11:06 PM
It's a sickness.
so about a month ago I bought/traded for a 72 914. a little rough here and there but a nice dry car.
the goal is to turn it into an improved car for auto-x and short track use (streets of willow) while still keeping it street legal and semi-tame.
for now I decided to stay with solid rotors to keep the budget under control.
so the brakes will be BMW in the front and stock ones in the rear.
I'm going with Koni sport shocks all around with a used Weltmeister front sway bar. I picked up a set of new 21mm front torsion cars and I have some 165lbs/in for the rear. yeah I could go higher spring rates in both the front and rear but the roads around here aren't too smooth and my fillings are loose.
here is some pictures of the work so far.
this is the new suspension next to the old stuff we took out.
here is a detail showing the zerk fittings we put in the front control arm mounts.
here is the rear suspension arm after boxing and with zerk fittings added along with new bearings and 5 lug conversion. I'll trim the studs after we get the rear wheels mounted and spaced to fit the GT flares.
here is the new rear suspension installed in the car. we left off the brakes as I will be taking the car to have the chassis stiffening kit installed. less work for the metal guy to remove the rear arms.
while the suspension work progresses I'm working on another engine for the car. right now the car has a stock 1.7 with FI. I bought a 2.0 off eBay that was local and ended up being reasonable. I also picked up a set of Weber 40IDF's for it.
the 2.0 won't go in the car until I get a side shifter trans sorted out for the car.
right now I need to get a set of front hubs cleaned and longer studs installed.
Cheers,
Kent
B2524
post Apr 11 2013, 11:57 AM
It's a sickness.
been a while since i posted any work.
here is my oil cooler setup under construction.
i mounted it in the back with 2 fans, using a large cooler i had sitting around.
i also mounted a catch tank.
i have a gel battery that will be mounted in the trunk, it isn't shown as i was working on the oil filter mount that is under it.
you'll see what what is going on when i get everything mounted in place.
as you can see i found an exhaust system. 1 3/4 as my engine is 'large'.
the little bracket is for the brake bias valve.
i should have some finished photos this weekend or next on most of these projects.
B2524   building an auto-x / short track / street car   Mar 30 2012, 11:06 PM
ruby914   Wow, Looking good. Your off to a good start and :...   Mar 30 2012, 11:16 PM
mrbubblehead   :agree: :wttc: it will be a blast to :driving: ...   Mar 30 2012, 11:44 PM
B2524   bump so the guys can see the old front suspension ...   Apr 6 2012, 09:57 AM
abnrdo   :wttc: Looks like a good start to a nice project...   Apr 6 2012, 11:18 PM
ChrisNPDrider   Nice :beer2: what's the plan for wheels/tire...   Apr 6 2012, 11:29 PM
B2524   I have a set of magnesium minilites that are powde...   Apr 7 2012, 05:40 PM
B2524   finally got the front rotors and hubs cleaned and ...   May 1 2012, 08:01 AM
B2524   progress: lots of work is now done and the car is...   Jul 25 2012, 09:11 AM
brant   progress: projects next up: Lexan rear window, b...   May 16 2013, 08:22 AM
B2524   forgot a picture of the aluminum door panels I mad...   Jul 25 2012, 09:17 AM
Dave_Darling   Which front struts, hubs, rotors, and calipers do ...   Jul 25 2012, 02:54 PM
B2524   i did something kind of sneaky. i had some 69 912 ...   Jul 25 2012, 03:45 PM
PatMc   i did something kind of sneaky. i had some 69 912...   Aug 18 2022, 09:34 PM
Dave_Darling   I wondered about that. Some early 911s had solid ...   Jul 25 2012, 09:21 PM
B2524   time to do a heart-lung transplant. here is the o...   Aug 9 2012, 07:42 AM
yeahmag   If you are tracking the car I'd suggest pluggi...   Aug 9 2012, 03:41 PM
Randal   Nice job on the trailing arms. You will love the ...   Aug 9 2012, 03:53 PM
B2524   the engine came with a nice cooler and remote filt...   Aug 10 2012, 07:19 AM
yeahmag   I think your best bet bang for $ is http://ww...   Aug 10 2012, 10:50 AM
B2524   been a while since i posted any work. here is my ...   Apr 11 2013, 11:57 AM
andys   so about a month ago I bought/traded for a 72 914...   Apr 11 2013, 01:13 PM
B2524   Phase one is almost complete: fresh brakes with B...   Apr 11 2013, 02:23 PM
B2524   well I was able to get the shock tower seams welde...   May 16 2013, 08:20 AM
B2524   Thanks for the tip. All cars are a compromise and...   May 16 2013, 08:22 PM
brant   Thanks for the tip. All cars are a compromise an...   May 16 2013, 08:55 PM
B2524   I just took the car to the body shop to have steel...   Dec 11 2015, 10:42 AM
B2524   time for an update. been busy with other stuff bu...   Sep 19 2016, 07:21 AM
B2524   Added 245-50 15's in the rear on 9x15 ARE...   Jan 21 2017, 01:26 PM
B2524   Moving right along I have the exhaust installed (r...   Feb 1 2020, 12:00 PM
barefoot   Moving right along I have the exhaust installed (...   Feb 1 2020, 01:01 PM
Daryl32   OK you have my attention!!!!!...   Feb 1 2020, 01:39 PM
Daryl32   I LOVE the steel flairs!!! By the way...   Feb 1 2020, 01:40 PM
B2524   Thermal expansion? Say what? I used a muffler hang...   Feb 1 2020, 06:48 PM
B2524   The angle iron is from an old bed frame. The hange...   Feb 1 2020, 06:53 PM
B2524   Here are more things I’ve done.   Feb 1 2020, 07:05 PM
B2524   This one didn’t load.   Feb 1 2020, 07:07 PM
B2524   Guess I missed two others Here is a learning expe...   Feb 1 2020, 07:17 PM
B2524   I was at a swap meet and found that rear valance. ...   Feb 1 2020, 07:31 PM
B2524   Oh yeah I forgot to mention. They ran a sport muff...   Feb 1 2020, 07:36 PM
B2524   One more thing I added to the build. I have a spa...   Feb 2 2020, 12:12 PM
sixnotfour   how old those Dunlops ??,,,, I had a nos pair I p...   Feb 2 2020, 03:53 PM
B2524   The rears are American Racing. They will build th...   Feb 2 2020, 05:00 PM
B2524   I’m going to bump this so it will be easy to fin...   Aug 18 2022, 09:12 PM
- Lo-Fi Version Time is now: 14th September 2026 - 11:05 AM
