> Engine Clanking Noise, Just looking for thoughts
Mblizzard
post Apr 11 2013, 07:19 PM
In the process of installing my dual carbs I spent a lot of time listening to the engine. I notice what I would classify as an internal clanking sound on the number 3 cylinder. Which of course varied with engine speed but is present to some degree at idle. I recently reset the valves so I am fairly sure it is not that as it has none of the tapping sound I associate with valve clearance issues. It is much more of a clunk. Engine runs well and has good compression so I am thinking it is a problem that is much deeper.
This is a 1.8 with a big bore (96mm x 66mm) and a mild cam. I am thinking piston wrist pin? I will go back and check the valves before doing anything but I thought I would see if someone might have suggestions on other possibilities
Any thoughts on other sources?
914itis
post Apr 11 2013, 09:13 PM
Are you sure it is from the engine, not the fuel pump or lose hear exhangers ?
Mblizzard   Engine Clanking Noise   Apr 11 2013, 07:19 PM
914itis   Are you sure it is from the engine, not the fuel p...   Apr 11 2013, 09:13 PM
timothy_nd28   Sounds like something fell inside your carb, then ...   Apr 11 2013, 09:13 PM
flippa   Sounds like something fell inside your carb, then...   Apr 11 2013, 09:27 PM
stugray   Get a mechanics stethoscope or use the "old s...   Apr 12 2013, 12:19 PM
MLedesma   All good advice above. However I pulled an engine...   Apr 12 2013, 12:25 PM
injunmort   loose valve seat?   Apr 12 2013, 02:03 PM
timothy_nd28   Something changed. Engine was doing fine till he ...   Apr 12 2013, 02:20 PM
Mblizzard   It was there before but I assumed it was just that...   Apr 12 2013, 03:50 PM
Mblizzard   FOD! That brings back memories.   Apr 12 2013, 03:52 PM
timothy_nd28   Sounds like you participated in those morning FOD ...   Apr 12 2013, 04:01 PM
stugray   I bought a 914 sight unseen. PO said that it was...   Apr 12 2013, 04:06 PM
Mblizzard   Well not in the service but I worked for the Air F...   Apr 12 2013, 06:41 PM
Mblizzard   You know sometimes I think I have things covered a...   Apr 12 2013, 06:46 PM
rhcb914   Check to see if you tightened down your valve adju...   Apr 12 2013, 07:12 PM
Elliot Cannon   A lot of what is described here would result in a ...   Apr 12 2013, 08:29 PM
dknechtly   Did you ever find out what the problem was?   Dec 18 2013, 08:05 AM
Mblizzard   Did you ever find out what the problem was? Ne...   Dec 18 2013, 09:57 AM
- Lo-Fi Version Time is now: 11th July 2025 - 04:55 PM
