> My New 914, ...only has 1 problem...
BMartin914
post Jul 2 2004, 11:37 AM
Seller just accepted my offer...
1975 Malaga Red 2.0...
Only has one problem...
The owner says that when he takes the car on long trips, or does any real hard driving to get the engine good and hot, that if he shuts it off, when he goes to restart it, the starter won't turn -- for about an hour until it cools down.
He says that there is no voltage loss at the solenoid and he does not believe the problem is caused by a relay.
Has anyone ever experienced this type of problem?
What was the remedy? Any advice will help.
I will take delivery of the car sometime next week. I plan on making this one of the first things I tackle.
attached is a pic of my new 914 (IMG:style_emoticons/default/driving.gif)
lapuwali
post Jul 2 2004, 01:34 PM
Not another one!
Some of you guys aren't reading the problem. He says the starter won't turn, not the car cranks but won't start. Therefore, this isn't a CHT or vapor lock problem.
It could very well be a ground issue. It could also be a bad starter, or a bad solenoid. I've seen both fail when hot, but work when they cool off. Clean the ground strap connections, if there is one. If that doesn't fix it, fit a rebuilt starter.
BMartin914   My New 914   Jul 2 2004, 11:37 AM
BMartin914   here's a pic :rolleyes:   Jul 2 2004, 11:39 AM
GWN7   The 70 used to do that. Had to park it on a hill. ...   Jul 2 2004, 11:46 AM
JmuRiz   Very common to have the hot-start problem. Check ...   Jul 2 2004, 11:51 AM
type47   75 should have a front mounted pump from the facto...   Jul 2 2004, 12:03 PM
tod914   could be ignition switch   Jul 2 2004, 12:11 PM
Andyrew   Its ground. Almost positive. Either buy a new grou...   Jul 2 2004, 12:14 PM
skline   Well, I had this problem once before also, it turn...   Jul 2 2004, 12:29 PM
Qarl   I don't think the CHT issue is a long term pro...   Jul 2 2004, 01:10 PM
scruz914   My '73 does exactly the same thing. I suspect...   Jul 2 2004, 01:22 PM
lapuwali   Some of you guys aren't reading the problem. ...   Jul 2 2004, 01:34 PM
brant   did I misunderstand...? why are we ruling out the ...   Jul 2 2004, 01:36 PM
BMartin914   From what I understand, I have (yet to) not experi...   Jul 2 2004, 02:01 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 11:09 PM
