Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
In the process of installing my dual carbs I spent a lot of time listening to the engine. I notice what I would classify as an internal clanking sound on the number 3 cylinder. Which of course varied with engine speed but is present to some degree at idle. I recently reset the valves so I am fairly sure it is not that as it has none of the tapping sound I associate with valve clearance issues. It is much more of a clunk. Engine runs well and has good compression so I am thinking it is a problem that is much deeper.
This is a 1.8 with a big bore (96mm x 66mm) and a mild cam. I am thinking piston wrist pin? I will go back and check the valves before doing anything but I thought I would see if someone might have suggestions on other possibilities Any thoughts on other sources? |
Mblizzard |
Well not in the service but I worked for the Air Force in certain capacities and when I first started I heard FOD and saw signs and had no idea what they were doing or talking about. As a result of that lack of knowledge I had to participated in a walk and listen to countless stories and instructions of what was FOD. I don't think I have to explain how memorable that was. For a while I would find all of FOD on my desk. Of course it often included items that while technically not FOD. The sources were not very likely. For example a size 1,000 (not really but they were huge) pair of women's panties! Yes I deserved it!
Lo-Fi Version | Time is now: 11th July 2025 - 04:47 PM |
