> Dual Carb Installation, Success - She Screams
Mblizzard
post Apr 5 2013, 07:36 PM
Working through the less than stellar instructions for the installation of my dual Webers. Beside having obvious errors in them it is not entirely clear which direction the cross bar should be pointed. To the front or the rear. I have not started placing the carbs on the car yet so the moment I move from the bench it may become clear but I think the front is correct. The directions seem to indicate that but if you install the linkage as shown one side of the crossbar link to the carb ends up at the front and the other at the back?
Mblizzard
post Apr 13 2013, 03:46 PM
Yep got the book. Read it. Can't say that anything in it that I tried made any difference. I plan to look through it one more time but even if there is something I missed it is hard for me to see how brand new carbs would or should behave this way.
Mblizzard   Dual Carb Installation   Apr 5 2013, 07:36 PM
Bob L.   Once installed on the engine the carbs will be sta...   Apr 5 2013, 07:48 PM
ConeDodger   The crossbar linkage should be installed in the ne...   Apr 5 2013, 08:03 PM
Mblizzard   May not be apparent but if you do the bench instal...   Apr 5 2013, 08:05 PM
r_towle   Towards the rear of the car.   Apr 5 2013, 08:06 PM
jmill   Towards the rear of the car. :agree: But wha...   Apr 5 2013, 08:20 PM
Mblizzard   I will be pulling from the front so looks like a f...   Apr 5 2013, 08:24 PM
Mblizzard   So if I "Call McMark for some good linkage...   Apr 6 2013, 05:54 AM
ConeDodger   So if I "Call McMark for some good linkage...   Apr 6 2013, 07:54 AM
r_towle   Original customs in Napa ca, or nearby. Mcmark her...   Apr 6 2013, 06:02 AM
rhodyguy   mike, i prefer the bar on the front. space is tigh...   Apr 6 2013, 06:24 AM
DBCooper   mike, i prefer the bar on the front. space is tig...   Apr 8 2013, 04:14 PM
Mblizzard   Kevin - You went through my check list. Timing de...   Apr 6 2013, 06:57 AM
rhodyguy   as ed china would say. "here's a top tip...   Apr 6 2013, 07:18 AM
audio_file   For the ultimate setup, call Chris Foley at tan...   Apr 6 2013, 08:03 AM
vw505   I looked on McMarks web site and didnt see it list...   Apr 6 2013, 02:39 PM
Mblizzard   Installation looks pretty good. Some set up still...   Apr 6 2013, 06:55 PM
Mblizzard   Beaten! Tried everything possible to get thes...   Apr 7 2013, 07:43 PM
ConeDodger   I repeat: Install in nearest garbage can... :D   Apr 7 2013, 07:51 PM
jmill   Are they new or did you rebuild them? Also you ne...   Apr 7 2013, 07:56 PM
Mblizzard   I used the ones that came with the new carbs. I h...   Apr 7 2013, 08:21 PM
jmill   Did you turn the throttle stops on both carbs equa...   Apr 7 2013, 08:29 PM
Mblizzard   Set the idle screws on both the the 1/2 turn after...   Apr 8 2013, 02:34 AM
ldsgeek   Try disconnecting the linkage from the carbs and s...   Apr 8 2013, 04:58 AM
rhodyguy   mike, you didn't get back to me. does the idle...   Apr 8 2013, 05:01 AM
Mblizzard   Kevin sorry I did not get back to you I was kind o...   Apr 8 2013, 12:34 PM
ThePaintedMan   Kevin sorry I did not get back to you I was kind ...   Apr 8 2013, 01:04 PM
Mblizzard   True with the faucet pump. But I have a reasonabl...   Apr 8 2013, 03:46 PM
ThePaintedMan   Seeing as the carbs are brand new I don't th...   Apr 8 2013, 04:25 PM
jmill   :agree: I always check the float level out of th...   Apr 8 2013, 08:14 PM
jmill   On a side note. I had a real steep driveway when ...   Apr 8 2013, 08:20 PM
Mblizzard   So I checked the float on one of the carbs. I gue...   Apr 9 2013, 04:49 AM
rhodyguy   hope i wasn't part of the "miffed". ...   Apr 9 2013, 07:18 AM
Mblizzard   Kevin you were not part of it! Your advice wa...   Apr 9 2013, 08:35 AM
ThePaintedMan   I think the float level being so far out account...   Apr 9 2013, 08:45 AM
rhodyguy   party on garth. ;) :)   Apr 9 2013, 08:40 AM
rhodyguy   the carbs found a way to relieve the fuel pressure...   Apr 9 2013, 09:03 AM
Mblizzard   I have read a number of the post on this forum whe...   Apr 9 2013, 04:37 PM
Mblizzard   John Kevin I am happy to a large degree of success...   Apr 9 2013, 07:38 PM
jmill   So I checked the float on one of the carbs. I gu...   Apr 9 2013, 07:43 PM
rpmmaxxed   Where did you purchase the carbs from? Reading thr...   Apr 9 2013, 08:08 PM
Mblizzard   John that is what I thought on the float setting. ...   Apr 9 2013, 08:19 PM
ThePaintedMan   John that is what I thought on the float setting....   Apr 9 2013, 08:25 PM
Mblizzard   I got the carbs from Redline. I would have to say...   Apr 9 2013, 08:34 PM
Mblizzard   While I was setting the carbs last night I happen ...   Apr 10 2013, 06:53 AM
rhodyguy   2 port exit breather box with the exits hooked to ...   Apr 10 2013, 07:02 AM
Mblizzard   CFR unit is what?   Apr 10 2013, 09:23 AM
'73-914kid   Tangerine Racing The CFR breather can is halfway ...   Apr 10 2013, 09:28 AM
AE354803   Is there any advantage to returning the crankcase ...   Apr 10 2013, 10:36 AM
Mblizzard   I was wondering that my self on the breather. Whi...   Apr 10 2013, 07:44 PM
jmill   Empi and Bugpak have cheaper $30ish options. ...   Apr 10 2013, 08:13 PM
Mblizzard   Well now this sucks beyond all imagination. Insta...   Apr 13 2013, 11:09 AM
DBCooper   Sounds like your idle circuit is dead. If you jus...   Apr 13 2013, 02:42 PM
DBCooper   Just thinking a little more, those are also the sy...   Apr 13 2013, 02:59 PM
Mblizzard   This has been a problem with the carbs since the f...   Apr 13 2013, 03:14 PM
DBCooper   This has been a problem with the carbs since the ...   Apr 13 2013, 03:26 PM
Mblizzard   Yep got the book. Read it. Can't say that anyt...   Apr 13 2013, 03:46 PM
Elliot Cannon   I've had problems like that and it was idle je...   Apr 13 2013, 09:45 PM
Mblizzard   Elliot - love the Red! The more I think abou...   Apr 14 2013, 07:12 AM
rhodyguy   call redline. see if they will take them back. you...   Apr 15 2013, 07:21 AM
Mblizzard   Talked with Redline. They think it is an idle jet ...   Apr 16 2013, 04:47 AM
ThePaintedMan   :agree: Selling used parts as "new" is a...   Apr 16 2013, 05:38 AM
rhodyguy   MIKE!! next step is contact your credit ca...   Apr 16 2013, 07:02 AM
Mblizzard   Following Kevin's suggestion, I contacted Amaz...   Apr 16 2013, 10:25 AM
timothy_nd28   I just hope that the carbs were indeed the problem...   Apr 16 2013, 10:30 AM
Mblizzard   The one thing I will give Redline credit for is th...   Apr 16 2013, 03:15 PM
ThePaintedMan   Something I thought about, which may or may not be...   Apr 16 2013, 03:25 PM
'73-914kid   Just going to put this out there: First off, the ...   Apr 16 2013, 03:53 PM
Mblizzard   I find it extremely hard to believe that this is a...   Apr 16 2013, 04:16 PM
'73-914kid   36mm Vent is HUGE for a 1911. My only thinking on ...   Apr 16 2013, 04:25 PM
brant   a 1911cc would probably be happy with a 28 or 30 v...   Apr 16 2013, 04:41 PM
Mblizzard   While the concerns with the size and Venturis are ...   Apr 16 2013, 06:21 PM
timothy_nd28   consider going back to the factory cam and FI :id...   Apr 16 2013, 06:26 PM
Mblizzard   Going back to FI is a long term goal. But if someo...   Apr 16 2013, 06:41 PM
ThePaintedMan   I didn't know you had 36 vents on there either...   Apr 16 2013, 06:43 PM
rhodyguy   the vents will certainly affect low speed operatio...   Apr 16 2013, 07:26 PM
Mblizzard   According to AEC they can go to 28 or 30 I think. ...   Apr 16 2013, 09:11 PM
rhodyguy   check your pms mike. share the idle jet advice fro...   Apr 17 2013, 06:05 AM
Mblizzard   I have new carbs in hand! Went through them. ...   Apr 20 2013, 07:52 PM
jmill   It'll run with the 36 vents. I had 44's w...   Apr 20 2013, 08:49 PM
Mblizzard   Well this set works. Still some work to do on the ...   Apr 21 2013, 06:29 PM
DBCooper   Not one, two steps forward. As it always is with ...   Apr 21 2013, 07:01 PM
Mblizzard   Ok I now have a set of 28mm Venturi's in hand ...   May 1 2013, 01:07 PM
Mblizzard   Well I seem to have had some major success! T...   May 1 2013, 07:55 PM
ThePaintedMan   Great to hear! Brant, Ethan and DB know this s...   May 1 2013, 08:39 PM
Mblizzard   George - They do look a little small. But while I...   May 2 2013, 08:54 AM
rhodyguy   mike, i'm really happy this is working for you...   May 2 2013, 01:11 PM
Mblizzard   Success! Took it out for a drive tonight afte...   May 2 2013, 08:30 PM
ThePaintedMan   :Qarl: :headbanger: :trophy: :driving:   May 2 2013, 08:38 PM
rhodyguy   'party on garth' :Qarl: . any snapping or...   May 3 2013, 06:40 AM
Mblizzard   Not a bit of snapping or popping. I only have abou...   May 3 2013, 09:21 AM
Mblizzard   Had a little hesitation when accelerating. Follow...   May 12 2013, 08:57 AM
Mblizzard   Wow that made a big difference. Still have a litt...   May 12 2013, 09:43 AM
Elliot Cannon   If you increase the idle jets, I would take it a l...   May 12 2013, 10:27 AM
Mblizzard   Elliot I have been making offers of American car p...   May 12 2013, 01:18 PM
Mblizzard   Well the end point was 75 on idle jet and decrease...   May 25 2013, 12:09 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:27 AM
