partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Before I go hog wild and pig cowrazy tearing into the door panel, the problem seems to be that from the inside when pulling the lever to open the door, it doesn't.
It will open from the outside. It locks, and unlocks just fine otherwise. Anybody know what the problem is? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I had that happen to me when I was mucking around with the internals of the door. I had swapped the screw for the window crank with the screw behind the door latch.
The window crank handle screw is slightly longer, and it keeps the inner door latch from opening all the way. If you've been working on the door since the last time it worked properly, this is definitely something to check. --DD |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
... The window crank handle screw is slightly longer, and it keeps the inner door latch from opening all the way. If you've been working on the door since the last time it worked properly, this is definitely something to check. --DD This has bitten me too... several times. Do this first, 5 minutes or less to check it! |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,739 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
... The window crank handle screw is slightly longer, and it keeps the inner door latch from opening all the way. If you've been working on the door since the last time it worked properly, this is definitely something to check. --DD This has bitten me too... several times. Do this first, 5 minutes or less to check it! And I thought that I was the only one dumb enough to have done this. Misery loves company. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 15th July 2025 - 02:52 AM |
