| 914Bryan |
Apr 13 2013, 01:46 PM
Member ![]() ![]() Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
Howdy, Im going to throw a bunch at you all at once.
I have just started to experience a return to idle problem with my 74 2.0 Djet. It runs ok, but when I stop and the engine returns to idle, it nearly dies. If it does stay running, the idle is surging. I have experimented with just pushing in the clutch and not downshifting and the engine nearly dies. Even if I downshift to gradually bring down the rpm, once it is in the idle range, it starts surging and nearly dies. I just reciently installed a new flywheel, clutch and pressure plate and adjusted the valves and did an oil change, but doubt that any of that would be a problem. But as an interesting side note, I did not weigh the new replacement flywheel; I know the one it replaced was a lightened unit. I have now noticed that the motor feels sluggish and does not rev as quickly as it did with the old lightened flywheel. Do you think that now it is spinning a heaver flywheel it is exposing a problem that a light flywheel covered-up? Any ideas where to start? |
| 76-914 |
Apr 14 2013, 10:02 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,866 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
We're not throwing you to the Wolve's Bryan. Dave is right about reading that link. I've re-read and perused that thing 50 times. At first you might be overwhelmed but it falls in place. You'll find that lean idle (or hunting) is a lean condition as Cabinetmaker mentions. If enriching the mixture doesn't help info for testing the TPS is there and quite simple to do with an ohm meter. ALL vacuum hoses must have air tight connections. If in doubt hose clamp it for now. Go to the site and look at all the D Jet components connected to vacuum. You can disconnect and plug all of these components except for the MPS (the one behind the battery with a 4prong conn and 10mm? vac line) and the car will run. If that corrects your idle hunting begin by adding one component at a time until problem returns then you've solved it.
914Bryan Return To Idle Problem Apr 13 2013, 01:46 PM
Vacca Rabite It feels more sluggish because you have a stock we... Apr 13 2013, 02:16 PM
914Bryan That's what I figured, but thought I would thr... Apr 13 2013, 03:02 PM
The Cabinetmaker Sounds like lean idle. Turn the ecu knob one click... Apr 13 2013, 03:55 PM
914Bryan
Sounds like lean idle. Turn the ecu knob one clic... Apr 13 2013, 07:51 PM
Bob L. Decel valve? :confused: Apr 13 2013, 04:44 PM
Dave_Darling ECU == Engine Control Unit. On the front side of ... Apr 13 2013, 11:29 PM
914Bryan OK, I downloaded and printed all the Djet info; lo... Apr 15 2013, 09:25 AM
76-914 correct. it has 22 positions, IIRC. Start in the m... Apr 15 2013, 09:39 AM
The Cabinetmaker Pull the rubber cover off the knob.
You'll see... Apr 15 2013, 10:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 01:01 AM |
