| Black914_4 |
Jan 19 2012, 07:11 AM
Member ![]() ![]() Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
Would someone mind explaning how the heater controls work please.
I have the '74 914 with the 2.0. I need to know what levers does what. ie. - middle lever moved to left does ..., to the right does.., bottom lever moved to left or right does... Thanks |
| 442nd914s |
Apr 14 2013, 08:25 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
Hope you guys don't mind if I piggy back off of this topic, but I have a related question.
What makes the defrost lamp cover to illuminate? My bulb, dash controls, and console switch work fine. Both blowers working and heat is available. However Im not getting any voltage to my indicator with the levers in any position. I've checked underneath the cover plate with the nut and screw connection. If I could just get some assistance on where check next. Everything else on the car works perfect (knock on wood). Thanks for your help |
2xs performance Heater Control question Jan 19 2012, 07:11 AM
flipb This is from memory, so others please correct me i... Jan 19 2012, 08:19 AM
Dave_Darling And far right on the top lever should turn on the ... Jan 19 2012, 12:42 PM
flipb
And far right on the top lever should turn on the... Jan 19 2012, 01:13 PM
Dave_Darling I always thought that the top lever was sort of a ... Jan 19 2012, 04:03 PM
mrholland2 How "needed" is the fresh air part? Is i... Jan 19 2012, 05:00 PM
Cevan Top lever controls the speed of the fresh air fan.... Jan 19 2012, 01:55 PM
Dave_Darling Only you can tell how "needed" it is. I... Jan 19 2012, 06:32 PM
GeorgeRud It's nice to be able to use both the fresh and... Jan 19 2012, 09:23 PM
johannes
It's nice to be able to use both the fresh an... Jan 20 2012, 08:00 AM
2xs performance I appriecate the help. That was what I needed to k... Jan 20 2012, 06:54 AM
partwerks You'd think that with the squirrel cage helper... Jan 20 2012, 08:05 AM
Dave_Darling
... Apr 14 2013, 10:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:44 PM |
