My 914-6 GT / 916 Project Car, Next project - 993 motor |
Steve |
Apr 14 2013, 09:44 PM
914 Guru Group: Members Posts: 5,611 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
My 914-6 GT / 916 project car started out as a stock 1975 2.0 carbureted 4 banger. I bought it in 1986, by 88 it had a 2.7 six in it with MSDS motor mount, headers and muffler. I also purchased brand new over the counter PMO 40 webers with manifolds for $1000.00. Those were the days!! I bought the tank, oil lines and tin over the counter from Porsche.
In 2000, the 2.7 started pulling head studs, so I replaced it with a 3.2 from a wrecking yard. In 2005 I sold the car and then bought it back 4 years later to the day. I later noticed that the inner wheel well had broken loose. Now starts the project of converting it from a race car back to a street car. I removed the battery tray this weekend for a better observation. It looks like battery acid caused the seam welds to rust. Which from racing caused the seam to separate. I bought the Harbor freight camera. I will try to get some internal shots next weekend to look for other rust damage. Looking at these pictures, what is the best way to repair this? This is a shot of the crack inside the wheel well. The rest of the shots are of the seam on the inside. I will also need to order an Engine shelf. This one is pretty toast. The battery tray is not that old, but was a bitch to get out. (IMG:style_emoticons/default/welder.gif) Thanks in advance for the help!!!! |
Mike Bellis |
Apr 14 2013, 09:58 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
That looks pretty good actually. Easy fix for the most part. The first picture looks suspect. Maybe some hidden treasures under that under coating.
Steve |
Apr 14 2013, 10:23 PM
That looks pretty good actually. Easy fix for the most part. The first picture looks suspect. Maybe some hidden treasures under that under coating. Thanks!! Actually the first picture is as bad as it looks. A while back before pulling the motor and battery tray, I wired brush this part down to bare metal. There was no rust, just this crack/rip in the metal. All I did at the time was spray paint it so the bare metal wouldn't start rusting. I will have to use a smaller wire wheel, like my Dremel tool, to get between the seem on the inside. From what I can tell, I just need a new Engine Shelf and a patch where the hole/rip is at. The rest I could probably hammer back and weld back up after getting it down to bare metal. The holes in the wall were where the body shop bolted the battery tray to the wall. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:57 AM |
