| PDXMike |
Apr 16 2013, 09:58 PM
Slowly Learning ![]() ![]() Group: Members Posts: 112 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
I need to remove the half axles so I can tow my motor less car. I have all of the bolts out, but I can't get the outer joints to separate. When I did the transmission ends I used a screwdriver to pry them apart. At the outer end I can't get anything inside the swing arm to do the prying.
I'm very tempted to just use the axle as a slide hammer to pull itself out, but that seems like a bad idea. I'm supposed to have this thing at the shop first thing tomorrow morning. Thanks! |
| bandjoey |
Apr 16 2013, 10:18 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
From what I've read. With axles off, the wheel and hub will roll out when going down the street. There are connectors for sale to join the 2 axles together.
Hopefully someone that knows for sure will jump in. |
PDXMike Half axle removal Apr 16 2013, 09:58 PM
McMark You can pull the outer stub axle. Or you can try,... Apr 16 2013, 10:32 PM
ThePaintedMan Here is a thread discussing the issue with some of... Apr 16 2013, 10:38 PM
PDXMike That thread makes it sound like I can remove the o... Apr 16 2013, 10:51 PM
jcd914 You're correct, removing the outer CV while le... Apr 16 2013, 11:20 PM
ThePaintedMan As Jim said Mike, it is possible to remove the out... Apr 16 2013, 11:27 PM
356'er I would avoid removing the stub axle, you may dama... Apr 17 2013, 12:25 AM
PDXMike So my options are:
Get creative/lucky and find a ... Apr 17 2013, 06:48 AM
The Cabinetmaker Option #3 is by far your best and safest bet. Apr 17 2013, 07:25 AM
McMark
Probably not rusty. Lots of grease in that area.... Apr 17 2013, 08:04 AM
PDXMike No luck so far, but I really didn't have a pla... Apr 17 2013, 08:44 AM
The Cabinetmaker Yep. your have to consider what your time is worth... Apr 17 2013, 01:32 PM
rwilner FWIW...I did the stub axle nut remove/install when... Apr 18 2013, 09:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 01:33 PM |
