ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Anyone know the weight of a stock 914 front hub/rotor and caliper?
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Rotor with bearings is about 15lbs.
Bare strut (no insert) is about 14lbs. Caliper is about 7lbs. Add in misc pieces (dust shield, pads, strut insert, etc) and you're probably up around 50-55lbs not including the A-arm. |
ww914 |
Rotor with bearings is about 15lbs. Bare strut (no insert) is about 14lbs. Caliper is about 7lbs. Add in misc pieces (dust shield, pads, strut insert, etc) and you're probably up around 50-55lbs not including the A-arm. I've been collecting parts to convert to 5 stud. My 911 rotors, Brembo calipers and hubs weight about 20.6 lbs together, so I guess they would be a tad lighter, assuming the struts weigh about the same. So the advantages I see are: 1 - A little lighter 2 - Bigger brake 3 - Easier to change wheels with studs rather than lug bolts. What else am I not considering? |
Lo-Fi Version | Time is now: 31st July 2025 - 07:22 PM |
