nick mironov |
nickm ![]() ![]() Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 ![]() |
After finding one rear bushing had failed, I replaced all of the rear bushings with a new Elephant re-greaseable polybronze bushing kit (including the shafts). The rear suspension still squeaks (not the front) I was under the impression that the Elephant bearings would cure the squeaking.
What else is there that could be sqeaking? Nick |
skeates |
Member ![]() ![]() Group: Members Posts: 219 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California ![]() |
Did the pitch or tone of the squeak change after you replaced the bushings? I wouldn't expect that the solid bushings are going to squeak in the same way that a rubber busing would when they bind (they don't bind and slip like a rubber bushing does). I would look elsewhere for the pesky noise. Can you recreate it by bouncing one of the rear quarters heavily by hand?
nick mironov |
Did the pitch or tone of the squeak change after you replaced the bushings? I wouldn't expect that the solid bushings are going to squeak in the same way that a rubber busing would when they bind (they don't bind and slip like a rubber bushing does). I would look elsewhere for the pesky noise. Can you recreate it by bouncing one of the rear quarters heavily by hand? The quality of the sound is about the same as before, but not quite so loud. It is most evident when the car is jacked up/down. It is hard to make the suspension make the squeaking sound by bouncing one of the rear quarters by hand because the suspension is very stiff - the car has 200 lb springs and a rear sway bar (V8). (I also replaced the sway bar bushings, and they are not the source of the sound). Nick |
skeates |
The quality of the sound is about the same as before, but not quite so loud. It is most evident when the car is jacked up/down. It is hard to make the suspension make the squeaking sound by bouncing one of the rear quarters by hand because the suspension is very stiff - the car has 200 lb springs and a rear sway bar (V8). (I also replaced the sway bar bushings, and they are not the source of the sound). Nick Can you tell whether or not the sound is coming from one particular side? If it is most evident when the car is jacked up/down you could try to isolate by placing the floor jack under one of the trailing arms and jack it up and down and try to listen where the sound is coming from (it might help to have a helper). You may need to disconnect the sway bar to do this to (if the squeak is still apparent then that would confirm that the sway bar is not the culprit). Also, just to confirm - when you installed the bronze bushings you pre-lubed them with grease right? |
Lo-Fi Version | Time is now: 3rd September 2025 - 08:22 PM |
