Ljet experts., I figure I will start this thread now. |
914itis |
Apr 18 2013, 08:08 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
My brother in Georgia is slowly putting back together a 75 ljet that I gave him. He's doing everything with my help over the phone.
For some reason he refuses to post here. Today, we finally got the engine started. It starts for a couples seconds and dies. The air cleaner assembly is still out. I know with djet the car will idle without the air cleaner. Is it the same with ljet or should we start looking elsewhere? |
timothy_nd28 |
Apr 18 2013, 09:18 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I don't think the air flow meter is connected. You stated that the car runs at idle for a few moments before it stumbles and dies. Having the AFM's 6 pin or 7 pin connector not attached to the AFM can cause this. The fuel pump is activated thru the dual relay. The dual relay first receives voltage from the ignition switch at the "start" position. As soon as you let go of the key, and it springs back to the "on" position, you lose the voltage going to the dual relay. (A hand off occurs at this point) With the engine idling, the AFM supplies voltage to the dual relay. Having no AFM connected, the dual relay will never receives this voltage, thus the fuel pump stops and the engine dies. I'm pretty sure if you add a jumper from pin 88d on the dual relay to the positive battery post, the car will continue to idle indefinitely. However, with no AFM, if you blip the throttle the engine will die.
skeates |
Apr 18 2013, 09:29 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
I don't think the air flow meter is connected. You stated that the car runs at idle for a few moments before it stumbles and dies. Having the AFM not installed, or the 7 pin connector not attached to the AFM can cause this. The fuel pump is activated thru the dual relay. The dual relay first receives voltage from the ignition switch at the "start" position. As soon as you let go of the key, and it springs back to the "on" position, you lose the voltage going to the dual relay. (A hand off occurs at this point) With the engine idling, the AFM supplies voltage to the dual relay. Having no AFM connected, the dual relay will never receives this voltage, thus the fuel pump stops and the engine dies. I'm pretty sure if you add a jumper from pin 88d on the dual relay to the positive battery post, the car will continue to idle indefinitely. However, with no AFM, if you blip the throttle the engine will die. (IMG:style_emoticons/default/agree.gif) sounds like the plug on afm isn't connectected. |
computers4kids |
Apr 18 2013, 09:47 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I don't think the air flow meter is connected. You stated that the car runs at idle for a few moments before it stumbles and dies. Having the AFM not installed, or the 7 pin connector not attached to the AFM can cause this. The fuel pump is activated thru the dual relay. The dual relay first receives voltage from the ignition switch at the "start" position. As soon as you let go of the key, and it springs back to the "on" position, you lose the voltage going to the dual relay. (A hand off occurs at this point) With the engine idling, the AFM supplies voltage to the dual relay. Having no AFM connected, the dual relay will never receives this voltage, thus the fuel pump stops and the engine dies. I'm pretty sure if you add a jumper from pin 88d on the dual relay to the positive battery post, the car will continue to idle indefinitely. However, with no AFM, if you blip the throttle the engine will die. (IMG:style_emoticons/default/agree.gif) sounds like the plug on afm isn't connectected. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 09:52 AM |
