'73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0" |
76-914 |
Jan 9 2013, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. And out she comes. One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. and an hour later I'm scraping tar floorboards. |
76-914 |
Apr 24 2013, 09:34 PM
I haven't posted here for a few days and thought that I had better get busy. If I'm doing the suspension I may as well do the brakes. I had previously done the fronts and now is the time for the rears. Check out Old Crusty. Not the Cap't., the caliper.....
So after dis assembly I'm left with this mess..... one dirty Ebrake return spring...... one clean spring, BTW, I cleaned this spring in < 2 min's (and many other brake parts) with a $5 3/4" copper fitting brush which I sawed the wooden handle off of and then chucked it into my bench top drill press. the brake lines were held with rubber jaws in the vise while I cleaned them with some sand cloth. 5 min's later some Shea stuff a little dab of self etching primer after parts are cleaned a little paint. the red is a VHT caliper paint whilst the silver is.......well it's silver some shiny parts and one dress rehearsal before final assembly and in place EDIT: If an Admin drops in would you pls remove the last two pics that I somehow added as an attachment and cannot remove. TIA, kent Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:35 PM |
