'73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0" |
76-914 |
Jan 9 2013, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. And out she comes. One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. and an hour later I'm scraping tar floorboards. |
Chris H. |
Apr 26 2013, 08:23 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
NIIICE! Great work Kent! That's a very strong motor and it's a lot smaller than the 3.3 and newer. I would not worry at all about the CEL as long as it runs OK. Could be something as simple as a wire with the coating worn off but it's probably a sensor or solenoid that you may or may not need. With the availability of used parts and the fact that many are universal across the Subie line there's not much you can't fix cheaply. Post the codes when you get them. Take your time stripping it. It's exhausting (Jeff, have you recovered (IMG:style_emoticons/default/biggrin.gif) ?) . Going through the wiring harness now. Worst part yet for sure. Family trumps car stuff any day. That's why mine is going pretty slow. Maybe I can catch up with you on the progress (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:40 AM |
