| gcrotvik |
Apr 17 2013, 09:28 AM
Member ![]() ![]() Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I am restoring a 74 914. I have a question regarding the grommets/drain tube(s) used in the 3 drain holes located in the front trunk area. The Porsche Pet does not show (at least that I can find) the grommet/drain tube types that were originally used by the factory. If you follow current thinking by Mark at 914Rubber, there is a 911 style drain tube that fits in the lowest drain hole. When I look up the associated 911 part number for this drain tube, it is not associated with the 914, only the 911 (for the front headlight buckets). If this is true, then the drain tube provided by 914Rubber is a good solution, but not original to the 914.
So here is my question. What did the factory use as grommets/drain tubes for the 3 drain holes in the front trunk? Part numbers? I have looked at many 914 front trunk pictures and it appears that the drain hole under the spare tire hold-down and the drain hole closest to the inner bulkhead are a grommet of some type. The drain hole closest to the front cross panel looks to be closed off with a solid plug. I am looking for concourse originality. Thank you for your help! Greg Attached image(s)
| orthobiz |
Apr 30 2013, 08:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
When I use it, I will post the new cleaner picture. Thanks, Pat.
Paul |
gcrotvik 1974 914 Front Trunk Originality Question Apr 17 2013, 09:28 AM
Pat Garvey I find it a new piece of education here. I am pre... Apr 17 2013, 06:58 PM
gcrotvik Pat,
Thank you for your expertise and feedback. W... Apr 18 2013, 08:31 AM
Pat Garvey
Pat,
Thank you for your expertise and feedback. ... Apr 18 2013, 06:21 PM
gcrotvik Thank you!! Apr 18 2013, 07:12 PM
orthobiz My 74, haven't gotten underneath it yet.
http... Apr 21 2013, 07:27 PM
Pat Garvey
Pau... Apr 28 2013, 05:31 PM
gcrotvik Thank you Paul! Your pictures are greatly appr... Apr 22 2013, 07:27 AM
gcrotvik I wanted to follow up on this thread. I was able t... Apr 26 2013, 07:52 AM
rnellums That is great Info! I had been wondering how ... Apr 30 2013, 07:54 AM
orthobiz The alcohol did not remove the stains. Went to the... May 25 2013, 03:37 PM
Pat Garvey
The alcohol did not remove the stains. Went to th... May 26 2013, 05:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:41 AM |
