> Hi torque starter, Not working
ruby914
post May 1 2013, 10:41 AM
I went to start the car after removing the motor for 6 months and the starter did nothing. (IMG:style_emoticons/default/confused24.gif)
I pulled it apart and can't understand how it works.
I put 12V direct to the main power buss and negative battery lead to the smaller plug and nothing.
If I move the 12V battery lead to the other side of the starter, to the main lead that goes to the motor, the Solenoid kicks out just fine.
If I move the negative lead to the starter body, the motor turns just fine.
The part I don't understand is that the main power lead goes to the "Solenoid switch contact" but nothing else. That's a dead end unless the solenoid is activated.
So what activates the solenoid?
I found this thread with lots of photos but no answer http://www.thesamba.com/vw/forum/viewtopic.php?t=384710
bulitt
post May 1 2013, 11:16 AM
Achtzylinder
When mounted on your motor/trans both the motor and the solenoid receive negative ground from the battery. No other negative wires are attached.
Put the 12v positive directly to the Positive buss on the starter.
The other buss on the starter is for positive coming from the ignition key (though a relay).
If you have a cheap starter switch from the local flaps you can put it between the positive buss on the starter and the solenoid buss. With the starter body grounded, and the pos from battery hooked to the pos buss, Push the button and the starter will turn.
Make sure the car is in neutral when you are doing this stuff!
When you energize the solenoid it completes the circuit allowing pos electricity from the pos buss to flow to the motor.
- Lo-Fi Version Time is now: 4th July 2025 - 12:28 AM
