last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
Okay so I had another thread troubleshooting these carbs but I've found the jetting to be the culprit. I am looking at Bob Tomlinson's suggestions and he is suggesting bw a 1.45 and 1.55 for the main jet. I currently have only a 1.15. I have a 52 for the idle and he recommends a 55. What do you guys think? I am running a stock 2.0.
Also, any suggestions on a vendor for jets? |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
A change in air correction jets results in a richer mix throughout the RPM range. Kinda. It depends on your ET. For the F11, 200 is the base line AC. Above 200 will lean the mixture at higher flows, below 200 will enrichen. AC jet changes won't affect idle at all and will do little to affect transition. You might want to look into a different ET. The F11 was designed to give a lean transition. |
Lo-Fi Version | Time is now: 2nd July 2025 - 10:03 PM |
