> I'm a stud, Repair guy, hopefully
Porschef
post Apr 10 2013, 07:05 PM
How you doin'
Well, it seems that the constant reoccurrence of an exhaust leak stemmed from a pulling exhaust stud. I'd tighten it, the noise would go away, come back, rinse, repeat.
A couple of weeks ago I took her out for a spin, heard that sound, and got under after cooling to see what the deal was.
A quarter turn later, the stud dropped right out.
So I'm gonna do an EZLOK insert, and pray.
Pics to follow, along with any tips, snags, or bonifide cuss sessions.
The fun never ends
Right Joe? (IMG:style_emoticons/default/hissyfit.gif)
Porschef
post May 2 2013, 07:56 PM
How you doin'
Lazy man finally posts pics...
Here's the hole from which the stud pulled out...
The tools required. Pretty basic- a drill index, a 27/64ths drill bit, ultimately, a 1/2"x13 tap, the same size sawn off to create a bottoming tap, and the EZ Loc.
The EZ Loc. Cost about four bucks at Fastenal.
Drilled it out, and tapped it. Then I ran the flat bottomed tap in a bit to make sure there was enough thread to grab...
The EZ Loc screwed right in
I forgot to take a pic of the stud in the insert. (IMG:style_emoticons/default/wacko.gif) I picked it up at the local Ace hardware. An 8mmx8mm exhaust stud. Cost just over 2 bucks. It had a flat, that would bottom out in the insert, without hitting the head. It was a little longer than the others, but the nut would tighten without any problem. After, reattaching the exchanger went fine.
All went well, the leak is gone.
Porschef   I'm a stud   Apr 10 2013, 07:05 PM
Rand   A step stud is a solid solution, no prayers needed...   Apr 10 2013, 07:14 PM
76-914   drill it in 3 steps i.e. use 3 different sizes wor...   Apr 10 2013, 07:17 PM
Rand   drill it in 3 steps i.e. use 3 different sizes wo...   Apr 10 2013, 07:28 PM
Porschef   Rand, Thanks for the offer. After getting twist...   Apr 10 2013, 07:49 PM
Rand   Rand, Thanks for the offer. After getting twis...   Apr 10 2013, 08:05 PM
ThePaintedMan   Don't let anyone fool you, it's not that h...   Apr 10 2013, 08:45 PM
Rand   Don't let anyone fool you, it's not that ...   Apr 10 2013, 10:13 PM
ThePaintedMan   Wait, what? About the step stud? You prefer an in...   Apr 11 2013, 07:32 AM
worn   I am afraid that Time Certs aren't magic and...   Apr 11 2013, 09:56 AM
ThePaintedMan   I am afraid that Time Certs aren't magic and...   Apr 11 2013, 10:02 AM
Porschef   Yes, heat exchanger is off.. :blink: I don...   Apr 11 2013, 04:35 AM
stugray   FWIW - in my business (aerospace) threads directly...   Apr 11 2013, 03:57 PM
yeahmag   Time Sert is the way to go. I think Aircooled.net ...   Apr 11 2013, 04:15 PM
yeahmag   http://vwparts.aircooled.net/Time-Sert-Thr...121-p...   Apr 11 2013, 04:26 PM
ThePaintedMan   Hmm... see, I may be painted, but I'm not craz...   Apr 11 2013, 04:49 PM
Porschef   Lazy man finally posts pics... Here's the ho...   May 2 2013, 07:56 PM
Chris H.   You sir are a stud (repair guy). :beer2:   May 3 2013, 07:52 AM
r_towle   Very nice. Is there red locktight on that insert ...   May 3 2013, 08:06 AM
stugray   I replaced the three exhaust studs that came out d...   May 3 2013, 10:24 AM
saigon71   Looks like a fine repair! :beer2:   May 3 2013, 05:01 PM
Porschef   Rich, yes, there's a loctite type material on ...   May 3 2013, 10:37 PM
stugray   Thanks for the tip! I posted a thread about ...   May 4 2013, 02:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:47 PM
