> It's running better..., Much better, Well even!!
Bob L.
post May 4 2013, 05:56 PM
After 10 months of cleaning, freshening and installing my donor motor, among other upgrades and repairs, I finally got the key turned and it started right up. Yippee for me!!
I have not let it run for long (exhaust leak) but it starts right up every time so far. Idle is at about 1850-1900 from a cold start. Is that normal? It's about 80 degrees out.
The main issue is that when I give it gas, it stalls.
I'm sure the timing must need adjusting.
The basics,
76 2.0 with stock D-jet in a 73(originally a 1.7)
EGR and air injection are gone.
Any suggestions where I should start?
It's nice to be able to consult so many experts all at one time.
Thanks all.
Bob L.
post May 4 2013, 09:30 PM
Update...
Vacuum leak.
I could feel the air rushing past my hand at the stacked F connector.
I think I fixed that. I'll try it again in the AM.
I still have to deal with timing and dwell.
Bob L.   It's running better...   May 4 2013, 05:56 PM
914itis   You may have a vaccum leak , chek for leaks. It sh...   May 4 2013, 06:00 PM
r_towle   Replace all rubber vacuum lines Replace all rubber...   May 4 2013, 06:01 PM
Bob L.   Replace all rubber vacuum lines Replace all rubbe...   May 4 2013, 06:10 PM
Bob L.   Update... Vacuum leak. I could feel the air rush...   May 4 2013, 09:30 PM
Bob L.   O.K. the idle is now on the low side, around 400-5...   May 6 2013, 01:58 PM
Bob L.   I have some new info. I pulled the plugs to reset...   May 11 2013, 01:06 PM
rick 918-S   Replace the cap, rotor and wires. Recheck the valv...   May 11 2013, 03:11 PM
r_towle   Valves and dwell affect timing. Car will run so m...   May 11 2013, 07:19 PM
Bob L.   OK, I replaced the points, Cap and rotor. Wires an...   May 12 2013, 06:51 PM
jmill   Handy dandy chart.   May 12 2013, 08:40 PM
Bob L.   Progress bump. It's been a banner day! I ...   May 19 2013, 07:24 PM
Dave_Darling   The timing is 27 deg BTDC at 3500 RPM. In theory,...   May 20 2013, 04:36 PM
Bob L.   Hi guys, thanks for sticking with me. The tune up ...   May 22 2013, 05:49 PM
Bob L.   I want to check my TPS reports. Is there a ref...   May 24 2013, 11:08 AM
Dave_Darling   Here: http://www.pelicanparts.com/techarticles/9....   May 24 2013, 12:49 PM
Bob L.   Here: http://www.pelicanparts.com/techarticles/9...   May 24 2013, 03:14 PM
Dave_Darling   There's no resistance on this particular part....   May 24 2013, 05:53 PM
Bob L.   There's no resistance on this particular part...   May 24 2013, 08:19 PM
Bob L.   O.K.! The TPS is adjusted. It did h...   May 25 2013, 05:02 PM
914itis   Is the advance in the distributor working properly...   May 25 2013, 05:06 PM
Bob L.   Is the advance in the distributor working properl...   May 25 2013, 05:26 PM
914itis   Connect a spare hose on the advanced and retard po...   May 25 2013, 06:37 PM
dangrouche   In all this, I did not see a mention of checking ...   May 25 2013, 08:03 PM
Bob L.   Itis, I did the sucking test for advance and re...   May 25 2013, 08:53 PM
Bob L.   And another thing... just because the vacuum adv...   May 25 2013, 09:02 PM
914itis   And another thing... just because the vacuum ad...   May 25 2013, 09:11 PM
Bob L.   And another thing... just because the vacuum a...   May 25 2013, 09:17 PM
914itis   [quote name='914itis' post='1869745' date='May 25...   May 25 2013, 09:19 PM
914itis   After testing the trigger points, if you are still...   May 25 2013, 09:04 PM
914itis   I also noticed that you mentioned 76 djet with 73....   May 25 2013, 09:08 PM
Bob L.   I also noticed that you mentioned 76 djet with 73...   May 25 2013, 09:51 PM
Bob L.   And yet another thing... I was searching around a...   May 25 2013, 09:14 PM
914itis   Adjusting the points gap is also know. As dwell, y...   May 25 2013, 09:18 PM
914itis   Reading your previous post, your dwell is at 48, n...   May 25 2013, 09:21 PM
Bob L.   Reading your previous post, your dwell is at 48, ...   May 25 2013, 09:26 PM
914itis   I am not sure about the centrifugal advance, but t...   May 25 2013, 09:31 PM
r_towle   I have found that you can chase an issue like this...   May 26 2013, 07:54 AM
Bob L.   R-towle, I was thinking that myself. I alread...   May 26 2013, 11:58 AM
914itis   It was not a dizzy rebuilt thread, it was the thre...   May 26 2013, 03:48 PM
Bob L.   It was not a dizzy rebuilt thread, it was the thr...   May 26 2013, 04:26 PM
Bob L.   Progress update... I have another dizzy from a 1...   May 27 2013, 03:27 PM
SLITS   Progress update... I have another dizzy from a ...   May 27 2013, 04:32 PM
Dave_Darling   Advance specs scraped from the factory manuals: h...   May 27 2013, 04:27 PM
Bob L.   Thanks Dave. Checking the stampings, it looks lik...   May 27 2013, 06:36 PM
914itis   I have a good working 2.0 dizzy, PM me if you are ...   May 27 2013, 08:09 PM
Bob L.   Update: Finally got the dizzy reconditioned. All...   Jun 8 2013, 06:41 PM
Bob L.   Update: :D :driving: I decided to start f...   Jun 15 2013, 04:53 PM
Cairo94507   Very cool. What a satisfying feel to have resolve...   Jun 16 2013, 07:16 AM
76-914   There is a plastic incased female spade fitting ju...   Jun 16 2013, 08:37 AM
Bob L.   There is a plastic incased female spade fitting j...   Jun 16 2013, 10:52 AM
- Lo-Fi Version Time is now: 9th June 2026 - 03:49 AM
