| Mblizzard |
May 7 2013, 07:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok seems simple. Voltage light on dash on. Battery dies. Replaced voltage regulator with a wells VR650. Light on dash off. All seems good. But voltmeter shows the voltage dropping the longer the car runs until it dies. Voltage does not change regardless of engine speed.
Put the old regulator back on. Light on dash stays on regardless of engine speed. But voltmeter shows an increase in voltage with engine speed. I have not gotten the battery charged yet to see if running the engine discharges the battery. I am at a loss as to what try next. |
| Mblizzard |
May 12 2013, 04:55 PM
Well went ahead and ordered new alternator. Did a final check of the wires tightened up all connections light still came on. Fine I resigned myself to doing the swap. Charged the battery to do a drive to test the newley installed jets. No generator light. Jamming out 13+ volts ran all day no problems?
This car is toying with me I know it! I guess I will keep the alternator on the work bench so the car can see it in order to have that intimidation factor! |
| r_towle |
May 13 2013, 03:18 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Well went ahead and ordered new alternator. Did a final check of the wires tightened up all connections light still came on. Fine I resigned myself to doing the swap. Charged the battery to do a drive to test the newley installed jets. No generator light. Jamming out 13+ volts ran all day no problems? This car is toying with me I know it! I guess I will keep the alternator on the work bench so the car can see it in order to have that intimidation factor! Go have someone do a load test on the battery. You may have a flaky cell that is causing this. rich |
Mblizzard Alternator - Voltage Regulator May 7 2013, 07:17 PM
r_towle Seriously, tap the VR a few times, it may be stuck... May 7 2013, 07:27 PM
bcheney
Seriously, tap the VR a few times, it may be stuc... May 7 2013, 08:27 PM
SLITS
Seriously, tap the VR a few times, it may be stu... May 8 2013, 06:48 AM
Mblizzard
Pull the alt and have it tested.
That is what I... May 8 2013, 07:23 AM
SLITS
That is what ... May 8 2013, 07:29 AM
luskesq
[quote name='bcheney' post='1860984' date='May 7 ... May 8 2013, 10:44 AM
SLITS
[quote name='bcheney' post='1860984' date='May 7... May 8 2013, 03:54 PM
Elliot Cannon
[quote name='luskesq' post='1861215' date='May 8 ... May 8 2013, 07:04 PM
Mblizzard
Seriously, tap the VR a few times, it may be stuc... May 7 2013, 08:48 PM
Cap'n Krusty Before you go any farther. Check the fuses and th... May 8 2013, 07:50 AM
bcheney
Before you go any farther. Check the fuses and t... May 8 2013, 08:10 AM
Mblizzard Hard to guess against the Captian! But if the... May 8 2013, 10:33 AM
AE354803 The solid state hella unit from Pelican Parts is g... May 8 2013, 07:09 PM
damesandhotrods I just replaced my voltage regulator about a month... May 8 2013, 11:22 AM
Drums66 ....My advice, convert to electronic(VR) :thumbsu... May 8 2013, 12:00 PM
damesandhotrods I goofed; it is a Hella not a Bosch. But judging ... May 8 2013, 12:06 PM
Mblizzard Did not find a voltage regulator on the bird site.... May 8 2013, 03:34 PM
Cap'n Krusty 914s are not known for losing cooling function whe... May 8 2013, 04:49 PM
ThePaintedMan
914s are not known for losing cooling function wh... May 8 2013, 05:08 PM
914s are not known for losing cooling function w... May 8 2013, 05:19 PM
ThePaintedMan
[quote name='ThePaintedMan' post='1861331' date='... May 9 2013, 07:30 AM
SLITS Ok Experts .... I run a 2.7L six. Wanna repeat th... May 8 2013, 06:24 PM
r_towle Even I remember slits runs a six cylinder....and I... May 8 2013, 06:26 PM
damesandhotrods Pelican Parts - Product Info
Electricity good… May 8 2013, 06:44 PM
Mblizzard Ok so here is the question. I have possibly two vo... May 8 2013, 07:41 PM
r_towle Is there an alternator test stand locally?
We have... May 8 2013, 07:44 PM
Mblizzard Ok so maybe I will get that kick inthe groin anywa... May 9 2013, 07:25 PM
r_towle its faster to leave the engine in the car.
Alterna... May 9 2013, 08:51 PM
Tom In post #15, you mentioned that the car died when ... May 10 2013, 01:31 PM
Mblizzard
In post #15, you mentioned that the car died when... May 10 2013, 02:29 PM
SLITS
In post #15, you mentioned that the car died whe... May 10 2013, 03:25 PM
worn
In post #15, you mentioned that the car died whe... May 13 2013, 03:11 PM
worn
Ok seems simple. Voltage light on dash on. Batte... May 10 2013, 02:07 PM
Steve Snyder
I was always taught and read that if you disconne... May 10 2013, 03:41 PM
damesandhotrods When I went for my mechanics license, the word was... May 10 2013, 05:17 PM
Tom Mblizzard,
I also am not an expert, however, my... May 10 2013, 06:34 PM
Mblizzard Tom thanks for the response. I really appreciate ... May 10 2013, 07:28 PM
Mblizzard Rich - brand new battery. Ran it all day no issu... May 13 2013, 07:21 PM
stugray
Worn nailed it.
The battery also acts as a volta... May 13 2013, 09:39 PM
tommy914 I'm having similar issues.
Alternator light gl... Jun 3 2013, 07:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:47 PM |
