73 Fuel Pump Dead - want to replace pump and lines - what all do I need? |
jbachert |
May 2 2013, 07:13 PM
Newbie Group: Members Posts: 40 Joined: 2-January 13 From: Allentown, PA Member No.: 15,329 Region Association: North East States |
1973 with original fuel injection and fuel pump in factory location.
Fuel pump is dead. I would like to do the following: 1) Replace factory fuel lines with stainless from Tangerine Racing - I have the original plastic lines in the tunnel and the original plastic lines in the engine compartment 2) Relocation the fuel pump to the front while I am at it - need a new fuel pump It seems the original "3 fuel line connection" pumps are no longer available So: 1) Which lines to I need to purchase from Tangerine to do this? 2) What fuel pump should I buy to install in the front of the car? Thanks, John |
914_teener |
May 15 2013, 06:20 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I mounted the later pump on the rear firewall on the passenger side with the stock mounts and some rivnuts.
Easy to get to and less work. I have had the car out in 110 temps here in stop and go traffic and no problems with vapor lock since I moved it and went to the later pump. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:57 PM |
