| LotusJoe |
May 16 2013, 06:44 PM
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I am experiencing wheel wobble at freeway speeds. At around 60 the steering wheel wobbles, but you can drive through it. At about 70 it quits. I assumed it was a tire out of balance. So I rotated the the backs to the front. No difference. I then put a different set of tires on the car. Same issue. Then I switched yet another set of tires from the race car. Same issue. Unless I have 4 sets of tires that are out of balance I'm a bit perplexed. The entire front end has completely new everything. Any thoughts on where to check? (IMG:style_emoticons/default/confused24.gif)
New: FreeMotion roller bearings on the arms Bilstein Sport Shocks Turbo Tie rods New tie rod ends New lower ball joints New upper polly bushings New wheel bearings New Rotors New Calipers New bushings on the sway bar (Everything is new) |
| JawjaPorsche |
May 16 2013, 06:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I assume you had the front end aligned after putting all those parts on? Just asking. (IMG:style_emoticons/default/biggrin.gif)
| LotusJoe |
May 16 2013, 06:50 PM
| JawjaPorsche |
May 16 2013, 06:53 PM
I assume you had the front end aligned after putting all those parts on? Just asking. Yes Crap, you are not making this easy to figure out. (IMG:style_emoticons/default/biggrin.gif) |
LotusJoe Steering Wheel Wobble at Speed May 16 2013, 06:44 PM
914itis Get all four balanced by a good tire shop and you ... May 16 2013, 06:54 PM
Elliot Cannon Adjust the front wheel bearings. Sounds like they... May 16 2013, 06:56 PM
Bartlett 914
Adjust the front wheel bearings. Sounds like the... May 16 2013, 07:34 PM
6freak
Adjust the front wheel bearings. Sounds like the... May 17 2013, 08:47 AM
76-914 :agree: May 16 2013, 07:10 PM
Jeffs9146 Letting the car sit to long on your tires, maybe y... May 16 2013, 07:28 PM
r_towle Steering rack? May 16 2013, 07:58 PM
worn
I am experiencing wheel wobble at freeway speeds.... May 16 2013, 09:01 PM
tomeric914 Tighten the wheel bearings and then tighten them a... May 16 2013, 09:55 PM
Garold Shaffer
Tighten the wheel bearings and then tighten them ... May 16 2013, 10:01 PM
Cap'n Krusty
I am experiencing wheel wobble at freeway speeds.... May 16 2013, 11:10 PM
L-Jet914 I am having the same issues as Lotus. Now off to ... May 17 2013, 12:02 AM
GeorgeRud Kind of a long shot, but you could also consider h... May 17 2013, 07:08 AM
Steve Snyder You might also want to ensure the four Allen bolts... May 17 2013, 08:35 AM
brant not a solution to your problem
but I don't lik... May 17 2013, 08:37 AM
LotusJoe Thanks for all the input.
I will attempt to answer... May 17 2013, 12:21 PM
Sandy Teener
I will attempt to answe... Sep 1 2015, 09:09 PM
r_towle I have seen more than a few steering racks that ha... May 17 2013, 02:17 PM
bulitt I would go through every nut and bolt and make sur... May 17 2013, 10:30 PM
Dasnowman Hubcentric rim rings ? Had a couple of vehicles w... May 18 2013, 01:57 AM
billh1963 What was the solution? Inquiring minds want to kno... Oct 18 2013, 01:57 PM
tadink hmmm, I've got the same thing, I thought it wa... Oct 18 2013, 06:32 PM
rhodyguy have you ever had your wheels checked for 'tru... Oct 19 2013, 07:47 AM
hedfurst You also might want to be sure the nuts that secur... Oct 19 2013, 08:06 AM
Porschef I lost the last bit of shimmy when I changed out t... Oct 19 2013, 08:53 PM
jkuehn Anyone figure this one out because i am the exact ... Nov 6 2013, 09:12 PM
914Mels You might have to look around for a shop that can ... Nov 7 2013, 02:36 PM
mzapisek I've been experiencing similar problems. Car ... Aug 12 2016, 12:51 PM
914_teener What is your suspension set up? Aug 12 2016, 01:30 PM
mzapisek From previous owners info:
"19mm thru body ... Aug 12 2016, 02:23 PM
914_teener So a 5 lug set up with a 19 mm through body bar an... Aug 12 2016, 02:33 PM
tradisrad I had this issue before and I had the tire shop ba... Aug 12 2016, 02:36 PM
ssuperflyoldguy Old school: car on ground- grab wheels 3&9 and... Aug 12 2016, 06:58 PM
Localboy808 I agree with other who have said to check every nu... Aug 12 2016, 07:43 PM
colingreene I put Lotus Joes car on a lift and checked all of ... Aug 12 2016, 08:33 PM
Sandy Teener
I put Lotus Joes car on a lift and checked all of... Aug 12 2016, 10:53 PM
Sandy Teener
I put Lotus Joes car on a lift and checked all of... Aug 12 2016, 10:54 PM
mzapisek OK underneath the car and everything looks good - ... Aug 13 2016, 08:10 AM
rhodyguy If you drive over a set of railroad tracks, or lik... Aug 13 2016, 12:49 PM
mzapisek Disconnected one drop link as others have advised.... Aug 13 2016, 06:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:08 AM |
