> 914World Classifieds Rules
> FS 914-6 Conversion & 914 Parts, Updated available and held items
Neil_J
post May 16 2013, 07:37 AM
Some parts are new upgrades never installed, others are from a well maintained 914 always garaged in California, now being converted to an 8. Location of parts are indicated by CA (San Francisco bay area) or NV (Las Vegas).
CA parts may be picked up locally or shipped FOB within the U.S.
Since this ad was posted on 3 forums there was a change in availability of NV parts. Originally, NV parts were to be shipped from Nevada but that became logistically difficult so those parts will be brought back to CA sometime in July and picked up or shipped from there. I will do my best to supply additional info for requested items. Parts will be held in the date stamp order of replies posted to ads in 3 forums. Ads will be updated with the current #1 positions.
Used items sold "as is". PM for additional info. Payment by cash, cashier's check or +3% for Paypal.
Rare 911 on-engine oil cooler modified for 914-6 conversions (right angle outlet allows hard oil lines to clear suspension) - good condition NV $400
Custom set of red Magnacor 8.5mm plug and ignition wires for Porsche flat 6 single plug engines - Used, good condition NV $100
MSD 6A unit - used, good condition NV $100
914-6 Oil Hose Line - Oil tank body shell to oil cooler hose line - Flexible center with metal formed ends 6k mi NV $40
914-6 Oil Hose Line - Tank to interface hard oil return pipe on engine - Flexible Line with Female M30 ends. 6k mi NV $25
Bursch 1 3/4" 2 in 1 out muffler with chrome tip 2k mi CA $200
914 Relay Board - Rebuilt and upgraded by Brad Mayeur - New unused CA $175
914 Blower Fan new unused CA $150
PARTS BEING HELD:
HELD FOR Goodbars (Pelican) 914-6 OEM oil tank with filler neck, cap, dipstick & filter console - 5k miles NV $900
HELD FOR David McLaughlin (Pelican) 914-6 fiberglass rear valence with hole for exhaust NV $100
HELD FOR Mr242 911 OEM 911 CUP air Intake with shortened snorkel and K&N filter (breathes great, quieter than water shields, allows for conversation in 914 cab) NV $100
HELD FOR carr914 914-6 complete fiberglass engine compartment "sheet metal" NV $80
HELD FOR Luke M KEP 9" 228mm clutch with 1500 lb pressure plate & custom flywheel: 5k miles NV $350
HELD FOR 1Trick6 used OEM 911 high torque starter motor (good match for 911 3.0L & 901 trans) NV $80
HELD FOR Luke M Exhaust hanger - used, good condition NV $20
HELD FOR carr914 Modified 2 in 1 out 911 muffler, matches 914-6 valence outlet hole - used good condition NV $100
HELD FOR scrz914 Carrera C-2/4 front oil cooler with manually switchable fan (temp switch defeated) NV $200
HELD FOR scrz914 Mocal OT/2 remote oil cooler thermostat for 12 AN fittings NV $80
HELD FOR Goldbars (Pelican) pair of 914 axles (8 k mi) with 4 CVs 4k mi $150
HELD FOR Luke M 914-6 Accelerator rod NV $80
HELD FOR Luke M 914-6 Throttle bell crank NV $50
HELD FOR Brant MSD Blaster coil - used, good condition NV $15
Luke M
post May 16 2013, 07:50 AM
Consider these items sold but need more info/pics. Can paypal once I hear back from you. Pm sent also.
Bursch 1 3/4" 914-6 Headers; installed for fitment, then removed (requires spacers, not included) CA $350
914-6 Oil Hose Line - Oil tank body shell to oil cooler hose line - Flexible center with metal formed ends. New unused CA $80
140 lb rear springs (pair) As new CA $120
Neil_J
post May 17 2013, 05:12 AM
Please hang on.. My wife had a run-in tonight with a deer in her WRX headlight. Literally!
All requests will be held in the order received. PM's not sent already will be sent on 5/18 then from the 20th.
To clarify:
"CA" parts are available to be shipped or picked up in San Francisco area.
Engine & carbs (separate or together) are available for pick up or ship on pallet from Las Vegas.
Other "NV" parts will be available as they come off the donor car which is at a reputable shop in Las Vegas. They have a few small projects before mine so this may take a few weeks. I will do my best to answer all requests and supply info and pics as parts become available.
Thanks for your patience.
-Neil
Neil_J   FS 914-6 Conversion & 914 Parts   May 16 2013, 07:37 AM
Luke M   Consider these items sold but need more info/pics....   May 16 2013, 07:50 AM
Neil_J   Please hang on.. My wife had a run-in tonight wit...   May 17 2013, 05:12 AM
carr914   I would like the Fiberglass Engine "Sheet Met...   May 16 2013, 08:22 AM
brant   2nd in line for the fiberglass engine tin please   May 16 2013, 09:00 AM
McMark   I'll take those headers. Sending a PM now.   May 16 2013, 09:32 AM
Neil_J   I'll take those headers. Sending a PM now. ...   May 17 2013, 07:50 AM
1TRICK6   PM sent on starter motor.   May 16 2013, 10:13 AM
Cool914   I will take the bell crank if it is for a non 914-...   May 16 2013, 12:00 PM
Vysoc   PM sent on Quick 6 Engine Mount. Vysoc   May 16 2013, 01:58 PM
shawn914   PM sent on 3.0 and RJohnson motor mount/kit   May 16 2013, 04:51 PM
Daiberl   PM sent on carbs.   May 16 2013, 07:02 PM
scrz914   sending pm on oil cooler and MoCal thermostat   May 16 2013, 09:17 PM
carr914   Did you get my pm?   May 17 2013, 05:16 AM
Mr.242   Interested: 911 OEM 911 CUP air Intake with shorte...   May 19 2013, 11:21 AM
Neil_J   Update SOLD - headers, springs and new oil lines....   May 27 2013, 06:16 PM
brant   Neil, I could use the blaster coil I "thin...   May 27 2013, 07:14 PM
Neil_J   You are 1st in line for the coil and fiberglass en...   May 27 2013, 07:43 PM
Neil_J   Brant, There was a PM miscommunication with anoth...   May 28 2013, 06:28 PM
carr914   HELD FOR brant 914-6 complete fiberglass engine ...   May 27 2013, 08:19 PM
Neil_J   T.C. My apologies. I thought you meant you were ...   May 27 2013, 09:17 PM
carr914   Neil, I believe I wrote in the pm (I delete my pm...   May 28 2013, 04:48 AM
Neil_J   You are back at 1st for the FG engine "metal...   May 28 2013, 05:27 AM
brant   no problem at all!   May 28 2013, 06:30 PM
- Lo-Fi Version Time is now: 9th June 2026 - 09:37 AM
