| 13b914 |
May 17 2013, 12:41 PM
Member ![]() ![]() Group: Members Posts: 75 Joined: 2-August 07 From: Youngstown Florida Member No.: 7,963 Region Association: None |
I have a ravenna green 1973 914 (No Motor). The car had minimal rust in the rear trunk that has been repaired and a slight amount of rust on the passenger side rear floor pan. The car is as solid as it can be. I added the chasis re-enforcement and I also welded in beef up plates for the rear suspension ears. I have pictures of the underside of the car while it was on the rottisserie and while it was bare metal. The rockers are all original and have no rust. It has metal flares, immitation fuchs. I was going to go watercooled so it already has a radiator with all the shrouding and fan set-up. I modified the front bumper with the 350Z billet grill as many others have done. I also fabbed a gt style engine grill. I would include new aftermarket bumper tops and just about all the rubber seals. The car has a 5 lug set-up from a 911 in the front and drilled rear hubs(all Bilstein and delrin bushings with grease fittings). It also has a 23mm front sway bar. The rear stock sway bar will come with the car but it's not installed. Also included would be powder coated black side mirrors along with powder coated black door handles. the rear valance is steel and has been fitted to the flares, the front valance is fiberglass and still needs fitment. Rear trunk is fiberglass and fits decent. The rocker panels are fiberglass and still need a little work but they are a close fit. the seats are grey leather and look really good. Also comes with a pearlon carpet kit. I have just about all the parts to put the car back together. I'm trying to get a ballpark number of what I should try to sell at. I'm sure there is plenty i'm leaving out.
| A&PGirl |
May 17 2013, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
I would go ahead repair the rust in the passage floor pan and document (pics in a binder) of doing so before in any paint or more assembly.
Documentation of work done does raise the price. Take very careful high resolution pictures all over the hellhole and down the long to reinforce the "rust free-ness" will help with a quicker sell and higher receiving price. Include the pedal cluster in the passenger compartment, on the underside and gas tank area as well. I would start at $6000 then raise the price with all work and reassembly carefully documented (in a binder w/pics & receipts). Do you have a clean and clear title for the car? Since I don't know what other work needs to be done or the condition things currently are all I can offer is my suggestion. |
13b914 What's it worth? May 17 2013, 12:41 PM
r_towle its a project car, so that values it much lower th... May 17 2013, 02:05 PM
its a project car, so that values it much lower t... May 17 2013, 08:17 PM
13b914 Thanks for your replies so far. All the rust repai... May 17 2013, 02:56 PM
vinniedatorch
Thanks for your replies so far. All the rust repa... May 18 2013, 09:04 PM
A&PGirl My line of thought was:
You are presenting the ca... May 17 2013, 03:46 PM
sixnotfour Don't under price yourself as little rust 914... May 17 2013, 08:29 PM
BIGKAT_83
Don't under price yourself as little rust 914... May 18 2013, 12:46 AM
siverson It's about $1000 to have a car shipped fr... May 17 2013, 09:03 PM
13b914 I'm gathering all the pictures of when the und... May 17 2013, 09:16 PM
13b914 I was leaning towards a ls1. The car is in Florida... May 18 2013, 07:11 AM
gopack I sold my project for $10000 NO engine, Trann... May 18 2013, 08:56 AM
Mikey914
I sold my project for $10000 NO engine, Tran... May 18 2013, 09:49 AM
moparrob The car would be an excellent candidate for a 914-... May 18 2013, 10:07 PM
dfelz
Sell the water cooled parts and let the next owne... May 18 2013, 10:25 PM
13b914 I want to thank everyone very much for weighing in... May 19 2013, 08:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:03 AM |
