| lsintampa |
May 17 2013, 11:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
914/4 75 2.0
Just installed new ATE brake master from PMB - the one for the 914/6 I use a pressure bleeder and have gone around about five times, first bleeding both top and bottom bleeders (RR, LR, LF, RF) then just the top ones. Had some weeping out of the RF bleeder overnight, so I bled them again - about three more times. No leaks that I can see, but pedal pressure is great with the pressure bleeder on, yet when I remove it, pedal pressure is OK, but the pedal travel is a bit much. I've no 914 seat time (yet), so I'm not sure if that amount of pedal travel is normal or not. I did tweak the rear pads, but I did it by feel... in other words I tightened up both piston until they were engaged and holding the rotor, then just backed off a bit on both sides to relieve the pressure. Anyway, it appears I have decent brakes, just a bit more pedal travel then what I'm used to. Thanks, Len |
| Eric_Shea |
May 17 2013, 02:02 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Do you have new seals in your calipers (freshly rebuilt)?
| lsintampa |
May 17 2013, 02:05 PM
lsintampa Brake pedal travel May 17 2013, 11:54 AM
Eric_Shea SOP
So now you need to bed the pads and season th... May 17 2013, 03:07 PM
lsintampa
SOP
So now you need to bed the pads and season t... May 17 2013, 03:34 PM
tomeric914 Well, it's taken me 3+ years to get the pedal ... May 17 2013, 04:41 PM
wndsrfr
Well, it's taken me 3+ years to get the pedal... May 17 2013, 05:24 PM
Cap'n Krusty Don't set the rear pad clearance by feel. Use... May 17 2013, 05:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 05:23 AM |
