> Brake pedal travel
lsintampa
post May 17 2013, 11:54 AM
914/4 75 2.0
Just installed new ATE brake master from PMB - the one for the 914/6
I use a pressure bleeder and have gone around about five times, first bleeding both top and bottom bleeders (RR, LR, LF, RF) then just the top ones.
Had some weeping out of the RF bleeder overnight, so I bled them again - about three more times.
No leaks that I can see, but pedal pressure is great with the pressure bleeder on, yet when I remove it, pedal pressure is OK, but the pedal travel is a bit much.
I've no 914 seat time (yet), so I'm not sure if that amount of pedal travel is normal or not.
I did tweak the rear pads, but I did it by feel... in other words I tightened up both piston until they were engaged and holding the rotor, then just backed off a bit on both sides to relieve the pressure.
Anyway, it appears I have decent brakes, just a bit more pedal travel then what I'm used to.
Thanks,
Len
tomeric914
post May 17 2013, 04:41 PM
One Lap of America in a 914!
Well, it's taken me 3+ years to get the pedal I want. New 19mm master cylinder? Nope, didn't do it. Rebuilt calipers? Nope didn't do it. Bedding of pads or maybe knockbacks that are to aggressive? Meh, could have been.
I thought that possibly the push rod was not adjusted correctly and holding the master cylinder piston in slightly, so I adjusted it to clearly have some play. No help.
I bled with a power bleeder for the first time this year and it made no difference before the first track event this year. However, after the event, I replaced the front pads after (obviously) expanding the caliper pistons. Ever since then I have had the pedal I have always wanted.
So what the heck was the reason? Possibly garbage in an internal circuit somewhere that got backflushed or some mystery bubble trapped in the line somewhere?
wndsrfr
post May 17 2013, 05:24 PM
QUOTE(tomeric914 @ May 17 2013, 02:41 PM) *
- Lo-Fi Version Time is now: 9th June 2026 - 04:14 AM
