| sfrenck |
May 17 2013, 06:06 PM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
Was installing my fog light switch tonight when I started coming across melted wires. 30 minutes later and I've traced the red power wire from the main fuses to the headlight switch to the green w/black tracer wire to the headlight motors.
All that length of wiring in the cabin is just about bare so I'm running a new wire the whole length. Anyway, back to the question, anyone know what gauge wire I should run? Guess that's one reason why my headlight motors are intermittent.... (IMG:style_emoticons/default/headbang.gif) |
| bdstone914 |
May 17 2013, 07:16 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I would do alot of poking around on the wiring harness before you start replacing wires, Normally when 1 wire melts in the twisted harness it melts through every other wire, I had a car with some weird electrical issues, Harness was melted from fuse panel to rear relay board. Use a multimeter, when random wires are shorted to eachother its bad.
| sfrenck |
May 17 2013, 07:34 PM
I would do alot of poking around on the wiring harness before you start replacing wires, Normally when 1 wire melts in the twisted harness it melts through every other wire, I had a car with some weird electrical issues, Harness was melted from fuse panel to rear relay board. Use a multimeter, when random wires are shorted to eachother its bad. Yeah was looking as I peeled and found some suspects. Sun was setting so I couldn't go through it as closely as I would like. The worst wire was between the fuse panel and the switch. Wonder if the DAPO had a fuse that was too high in the panel at some point? Also of interest, my yellow car has orange dash metal.... |
sfrenck Green w/black tracer wire to headlight motors: May 17 2013, 06:06 PM
Jeff Bowlsby
Was installing my fog light switch tonight when I... May 17 2013, 06:31 PM
kg6dxn If you are running new, use 16ga wire. It is an up... May 17 2013, 07:08 PM
Jeff Bowlsby
If you are running new, use 16ga wire. It is an u... May 18 2013, 10:14 AM
Jeff Bowlsby
Also of interest, my yellow car has orange dash m... May 18 2013, 10:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:07 AM |
