> Gradually worsening clutch chatter- cause?, Update- Autopsy Complete!!!
tornik550
post May 17 2013, 07:54 PM
I took my engine out of the winter when my car was being painted. I made a few small changes to the engine when it was out. Most had nothing to do with the clutch. I did remove the clutch/flywheel to install a new rear main seal. My engine is back in and running great.
When I try to take off in first gear, I get a fairly large amount of clutch chatter. It seems to be worsening.
Details
-never had any issues until I reinstalled my engine
-clutch disk has about 500 miles on it.
-flywheel/pressure plate appeared normal when reinstalled
-engine/transmission mounts are good
-transmission was rebuilt by dr evil about a year ago
-throw out bearing was fine then
Ideas?
Is it possible that my clutch is simply not adjusted right?
tornik550   Gradually worsening clutch chatter- cause?   May 17 2013, 07:54 PM
Jeff Hail   I took my engine out of the winter when my car wa...   May 17 2013, 08:08 PM
Dr Evil   Has your flywheel been resurfaced? Did you put the...   May 17 2013, 08:10 PM
Jeff Hail   Has your flywheel been resurfaced? Did you put th...   May 17 2013, 08:22 PM
kg6dxn   If it's not the clutch disk or pressure plate,...   May 17 2013, 08:27 PM
messix   loose flywheel bolts... no lock tight? better ta...   May 17 2013, 09:01 PM
tornik550   I cannot see how my flywheel could be warped cause...   May 18 2013, 07:39 AM
Dr Evil   As stated before, definitely check all mounts.   May 18 2013, 11:08 AM
tornik550   As stated before, definitely check all mounts. ...   May 18 2013, 01:35 PM
rick 918-S   Not likely caused by adjustment. I would say check...   May 18 2013, 02:18 PM
Drums66   ....I'm with the loose bolts or alignment? :i...   May 18 2013, 02:28 PM
tornik550   Alright- looks like I'll be doing an autopsy t...   May 18 2013, 02:43 PM
tornik550   I just took my tranny in my personal best time- 45...   May 18 2013, 07:14 PM
r_towle   No oil leaks from the tranny? How about any oil in...   May 18 2013, 07:26 PM
tornik550   No oil leaks from the tranny. No oil in the bell...   May 18 2013, 07:32 PM
tornik550   RE: Gradually worsening clutch chatter- cause?   May 18 2013, 07:33 PM
tornik550   So I am obviously buying a new clutch disk. How...   May 18 2013, 07:35 PM
r_towle   Personal choice....can you clean it with brake Kle...   May 18 2013, 07:38 PM
tornik550   I decided to just buy them both. I would feel mu...   May 18 2013, 07:47 PM
messix   its hard to see from the picture quality but does ...   May 18 2013, 08:26 PM
tornik550   its hard to see from the picture quality but does...   May 18 2013, 08:33 PM
messix   and you did check the torque on the flywheel bolts...   May 18 2013, 08:28 PM
rick 918-S   PP is warped.   May 18 2013, 08:40 PM
bandjoey   So is mine. What's that got to do with his clu...   May 18 2013, 08:50 PM
- Lo-Fi Version Time is now: 9th June 2026 - 04:06 AM
