| tornik550 |
May 17 2013, 07:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I took my engine out of the winter when my car was being painted. I made a few small changes to the engine when it was out. Most had nothing to do with the clutch. I did remove the clutch/flywheel to install a new rear main seal. My engine is back in and running great.
When I try to take off in first gear, I get a fairly large amount of clutch chatter. It seems to be worsening. Details -never had any issues until I reinstalled my engine -clutch disk has about 500 miles on it. -flywheel/pressure plate appeared normal when reinstalled -engine/transmission mounts are good -transmission was rebuilt by dr evil about a year ago -throw out bearing was fine then Ideas? Is it possible that my clutch is simply not adjusted right? |
| r_towle |
May 18 2013, 07:26 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
No oil leaks from the tranny?
How about any oil inside the bell housing? You may have contaminated the clutch disk, then burned it. I would replace the disk at a minimum. |
tornik550 Gradually worsening clutch chatter- cause? May 17 2013, 07:54 PM
Jeff Hail
I took my engine out of the winter when my car wa... May 17 2013, 08:08 PM
Dr Evil Has your flywheel been resurfaced? Did you put the... May 17 2013, 08:10 PM
Jeff Hail
Has your flywheel been resurfaced? Did you put th... May 17 2013, 08:22 PM
kg6dxn If it's not the clutch disk or pressure plate,... May 17 2013, 08:27 PM
messix loose flywheel bolts... no lock tight?
better ta... May 17 2013, 09:01 PM
tornik550 I cannot see how my flywheel could be warped cause... May 18 2013, 07:39 AM
Dr Evil As stated before, definitely check all mounts. May 18 2013, 11:08 AM
tornik550
... May 18 2013, 01:35 PM
rick 918-S Not likely caused by adjustment. I would say check... May 18 2013, 02:18 PM
Drums66 ....I'm with the loose bolts or alignment? :i... May 18 2013, 02:28 PM
tornik550 Alright- looks like I'll be doing an autopsy t... May 18 2013, 02:43 PM
tornik550 I just took my tranny in my personal best time- 45... May 18 2013, 07:14 PM
tornik550 No oil leaks from the tranny. No oil in the bell... May 18 2013, 07:32 PM
tornik550 RE: Gradually worsening clutch chatter- cause? May 18 2013, 07:33 PM
tornik550 So I am obviously buying a new clutch disk.
How... May 18 2013, 07:35 PM
r_towle Personal choice....can you clean it with brake Kle... May 18 2013, 07:38 PM
tornik550 I decided to just buy them both. I would feel mu... May 18 2013, 07:47 PM
messix its hard to see from the picture quality but does ... May 18 2013, 08:26 PM
tornik550
its hard to see from the picture quality but does... May 18 2013, 08:33 PM
messix and you did check the torque on the flywheel bolts... May 18 2013, 08:28 PM
rick 918-S PP is warped. May 18 2013, 08:40 PM
bandjoey So is mine. What's that got to do with his clu... May 18 2013, 08:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:11 AM |
