| tornik550 |
May 17 2013, 07:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I took my engine out of the winter when my car was being painted. I made a few small changes to the engine when it was out. Most had nothing to do with the clutch. I did remove the clutch/flywheel to install a new rear main seal. My engine is back in and running great.
When I try to take off in first gear, I get a fairly large amount of clutch chatter. It seems to be worsening. Details -never had any issues until I reinstalled my engine -clutch disk has about 500 miles on it. -flywheel/pressure plate appeared normal when reinstalled -engine/transmission mounts are good -transmission was rebuilt by dr evil about a year ago -throw out bearing was fine then Ideas? Is it possible that my clutch is simply not adjusted right? |
| messix |
May 18 2013, 08:26 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
its hard to see from the picture quality but does it look like the pp was only working on the outer edge of the disk?
it doesn't look like there is any wear on the inner 2/3 of the disk. |
| tornik550 |
May 18 2013, 08:33 PM
its hard to see from the picture quality but does it look like the pp was only working on the outer edge of the disk? it doesn't look like there is any wear on the inner 2/3 of the disk. I was having a hard time getting the scorching to show properly in the pictures. I think it is just the pictures. The whole disk looks pretty bad. Also, I did check the flywheel torque values- all ok. |
tornik550 Gradually worsening clutch chatter- cause? May 17 2013, 07:54 PM
Jeff Hail
I took my engine out of the winter when my car wa... May 17 2013, 08:08 PM
Dr Evil Has your flywheel been resurfaced? Did you put the... May 17 2013, 08:10 PM
Jeff Hail
Has your flywheel been resurfaced? Did you put th... May 17 2013, 08:22 PM
kg6dxn If it's not the clutch disk or pressure plate,... May 17 2013, 08:27 PM
messix loose flywheel bolts... no lock tight?
better ta... May 17 2013, 09:01 PM
tornik550 I cannot see how my flywheel could be warped cause... May 18 2013, 07:39 AM
Dr Evil As stated before, definitely check all mounts. May 18 2013, 11:08 AM
tornik550
... May 18 2013, 01:35 PM
rick 918-S Not likely caused by adjustment. I would say check... May 18 2013, 02:18 PM
Drums66 ....I'm with the loose bolts or alignment? :i... May 18 2013, 02:28 PM
tornik550 Alright- looks like I'll be doing an autopsy t... May 18 2013, 02:43 PM
tornik550 I just took my tranny in my personal best time- 45... May 18 2013, 07:14 PM
r_towle No oil leaks from the tranny?
How about any oil in... May 18 2013, 07:26 PM
tornik550 No oil leaks from the tranny. No oil in the bell... May 18 2013, 07:32 PM
tornik550 RE: Gradually worsening clutch chatter- cause? May 18 2013, 07:33 PM
tornik550 So I am obviously buying a new clutch disk.
How... May 18 2013, 07:35 PM
r_towle Personal choice....can you clean it with brake Kle... May 18 2013, 07:38 PM
tornik550 I decided to just buy them both. I would feel mu... May 18 2013, 07:47 PM
messix and you did check the torque on the flywheel bolts... May 18 2013, 08:28 PM
rick 918-S PP is warped. May 18 2013, 08:40 PM
bandjoey So is mine. What's that got to do with his clu... May 18 2013, 08:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:18 AM |
