| Eric_Shea |
Jun 17 2012, 05:36 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hey Gang,
Installing the heater control cable and ran into a problem. Yes, I realize there is a left and a right (longer/shorter etc.) but, after trying both ways it appears the cable is bent wrong from the factory. I'm about 3.5" off each way. Has anyone run into this in the past? Too Short: Too Long: |
| mepstein |
May 19 2013, 06:20 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,753 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I had to rebend mine. Worked perfectly when the passenger side was 2" longer than the driver side. (as per eric's suggestion)
| JawjaPorsche |
May 19 2013, 09:10 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I had to rebend mine. Worked perfectly when the passenger side was 2" longer than the driver side. (as per eric's suggestion) (IMG:style_emoticons/default/agree.gif) I had the same problem. Tried it both ways then measured old cable and rebent and it worked. Terry |
Eric_Shea Heater Pull Cable Jun 17 2012, 05:36 PM
A&PGirl That's the same as my new Porsche Cable. The o... Jun 17 2012, 06:10 PM
Eric_Shea So I'm not hallucinating from the brake cleane... Jun 17 2012, 06:14 PM
A&PGirl Maybe they used a batch of 911 cables and slapped ... Jun 17 2012, 06:20 PM
JimN73 I had the same problem and ended up using some oth... Jun 17 2012, 06:34 PM
Spoke Are they equal lengths from the bend? Can you stra... Jun 17 2012, 06:52 PM
Eric_Shea I was successful in re-bending the original. Had ... Jun 18 2012, 02:51 PM
tomeric914
I was successful in re-bending the original. Had... May 18 2013, 09:39 PM
Cap'n Krusty WHAT? If the long side was 3.5" too long and... May 18 2013, 10:21 PM
Eric_Shea
WHAT? If the long side was 3.5" too long an... May 18 2013, 11:29 PM
tomeric914
WHAT? If the long side was 3.5" too long a... May 19 2013, 06:13 AM
jeffdon Heat? Oh, All that stuff. May 18 2013, 10:33 PM
Drums66
......Go Heat,(Miam... May 19 2013, 11:59 AM
SLITS I'm not that anal ... I just clamped the wire ... May 19 2013, 09:37 AM
76-914
I'm not that anal ... I just clamped the wire... May 19 2013, 10:30 AM
Eric_Shea
I'm not that anal ... I just clamped the wir... May 19 2013, 02:04 PM
TJB/914 Hey,
I am having the same problem with too long ... May 19 2013, 10:37 AM
Hey,
I am having the same problem with too long ... May 19 2013, 10:46 AM
TJB/914
Hey,
I am having the same problem with too long... May 19 2013, 11:10 AM
Jeff Hail
Hey Gang,
Installing the heater control cable an... May 19 2013, 10:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 PM |
