| Eric_Shea |
Jun 17 2012, 05:36 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hey Gang,
Installing the heater control cable and ran into a problem. Yes, I realize there is a left and a right (longer/shorter etc.) but, after trying both ways it appears the cable is bent wrong from the factory. I'm about 3.5" off each way. Has anyone run into this in the past? Too Short: Too Long: |
| SLITS |
May 19 2013, 09:37 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I'm not that anal ... I just clamped the wire in the barrel nut ... it works.
Shame on you Erc ... those aren't real 914/6 flapper valves ... (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1368978196.1.jpg) |
| 76-914 |
May 19 2013, 10:30 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,894 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I'm not that anal ... I just clamped the wire in the barrel nut ... it works. Shame on you Erc ... those aren't real 914/6 flapper valves ... (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1368978196.1.jpg) Does this mean Erc is banned from future 914 events until this oversite is corrected? |
| Eric_Shea |
May 19 2013, 02:04 PM
I'm not that anal ... I just clamped the wire in the barrel nut ... it works. Shame on you Erc ... those aren't real 914/6 flapper valves ... (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1368978196.1.jpg) Does this mean Erc is banned from future 914 events until this oversite is corrected? No. It means slits is going to send me a pair of -6 boxes for the trailer queen. (IMG:style_emoticons/default/w00t.gif) |
Eric_Shea Heater Pull Cable Jun 17 2012, 05:36 PM
A&PGirl That's the same as my new Porsche Cable. The o... Jun 17 2012, 06:10 PM
Eric_Shea So I'm not hallucinating from the brake cleane... Jun 17 2012, 06:14 PM
A&PGirl Maybe they used a batch of 911 cables and slapped ... Jun 17 2012, 06:20 PM
JimN73 I had the same problem and ended up using some oth... Jun 17 2012, 06:34 PM
Spoke Are they equal lengths from the bend? Can you stra... Jun 17 2012, 06:52 PM
Eric_Shea I was successful in re-bending the original. Had ... Jun 18 2012, 02:51 PM
tomeric914
I was successful in re-bending the original. Had... May 18 2013, 09:39 PM
Cap'n Krusty WHAT? If the long side was 3.5" too long and... May 18 2013, 10:21 PM
Eric_Shea
WHAT? If the long side was 3.5" too long an... May 18 2013, 11:29 PM
tomeric914
WHAT? If the long side was 3.5" too long a... May 19 2013, 06:13 AM
jeffdon Heat? Oh, All that stuff. May 18 2013, 10:33 PM
Drums66
......Go Heat,(Miam... May 19 2013, 11:59 AM
mepstein I had to rebend mine. Worked perfectly when the pa... May 19 2013, 06:20 AM
JawjaPorsche
I had to rebend mine. Worked perfectly when the p... May 19 2013, 09:10 AM
TJB/914 Hey,
I am having the same problem with too long ... May 19 2013, 10:37 AM
Hey,
I am having the same problem with too long ... May 19 2013, 10:46 AM
TJB/914
Hey,
I am having the same problem with too long... May 19 2013, 11:10 AM
Jeff Hail
Hey Gang,
Installing the heater control cable an... May 19 2013, 10:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:27 PM |
