| parrish911 |
May 18 2013, 04:14 PM
Newbie ![]() Group: Members Posts: 35 Joined: 27-April 06 Member No.: 5,939 Region Association: South East States |
I have a '73 2.0 that is primarily used for auto-x with occasional weekend drives. I live in Tampa, FL. There is a copper bellows type thermostat that is used to control a flapper valve that routes cooling air. The bellows expands with heat and gradually opens the flapper valve, directing more air to the cylinders.
My question, is there any downside to bypassing the bellows and leaving the flapper valve in the always open position? I don't really deal with 'cold' weather and I am not convinced there is any benefit to having this on the engine, given how I am using the car. I would welcome your thoughts on this. Thanks, Steve |
| parrish911 |
May 19 2013, 03:19 PM
Wow, thanks for all the responses. I will try to answer the questions posed. My concern with the thermostat was @ 40 yrs old it may not be fully functional and is really not needed here in Florida. I did not think about cooking off the water in the oil. I did test the thermostat in water and it does appear to function. I measured a heated length of 46mm @ 155 F (I found this test in the Porsche shop manual).
Dumb question: is this thermostat present in all 914/4 engines? Bill Andrews, have you seen the oil/water sludge with your 914 during Texas summers? Again, I really appreciate all the responses. As everything appears to be functional, I think I will lube everything up (flap hinges & cable pulley) and reattach it. Steve |
parrish911 914 2.0 cooling question May 18 2013, 04:14 PM
bandjoey I don't think it matters in hot weather. I ke... May 18 2013, 04:23 PM
parrish911 Thanks Bill. I was thinking the same thing. Plu... May 18 2013, 05:54 PM
nathansnathan Without the thermostat, the engine will take a lon... May 19 2013, 02:05 AM
SirAndy Without the thermostat, the engine will take a lon... May 19 2013, 11:54 AM
Rand
But what do you think is the downside of running ... May 19 2013, 12:03 PM
Bleyseng Leave it in as it speeds warmup as VW/Porsche had ... May 19 2013, 07:50 AM
Drums66 .....Modus Operandi! :idea:
:wavebye: May 19 2013, 11:48 AM
Rand Yes, as said, it means slower warmup. Would you re... May 19 2013, 11:51 AM
Dave_Darling The thermostat is present in all 914-4 engines as ... May 19 2013, 04:16 PM
Cap'n Krusty The failure mode of the thermostat would be in the... May 19 2013, 04:40 PM
ww914
The failure mode of the thermostat would be in th... May 20 2013, 05:17 PM
Elliot Cannon My thermostat/bellows have been removed since the ... May 19 2013, 05:07 PM
mrholland2 My engine installing mechanic installed the flaps ... May 19 2013, 07:43 PM
SirAndy The concern wasn't the thermostat as much as i... May 20 2013, 12:11 AM
bandjoey My daily drive is 30 miles each way. I don't h... May 19 2013, 10:13 PM
Dave_Darling Oh yes, they can get stuck closed! Trust me o... May 20 2013, 04:29 PM
SirAndy Oh yes, they can get stuck closed! Trust me o... May 20 2013, 05:01 PM
Dave_Darling
Have you seen the spring on that thing?
One woul... May 20 2013, 08:51 PM
ww914
One wou... May 20 2013, 09:23 PM
SirAndy Just convince me I am wrong.
You are wrong! T... May 20 2013, 09:29 PM
ww914
You are wrong! ... May 20 2013, 11:08 PM
SirAndy [quote name='SirAndy' post='1867067' date='May 20 ... May 20 2013, 11:24 PM
ww914 Well, crow isn't so bad. Thanks Andy for findi... May 21 2013, 07:57 AM
stugray I am putting the shrouds on my race engine.
I had ... May 26 2013, 01:12 PM
Rand
I had... May 26 2013, 07:36 PM
Drums66
After reading this I guess that on an engine wi... May 26 2013, 07:54 PM
SirAndy After reading this I guess that on an engine with ... May 26 2013, 09:55 PM
Alapone Sorry I have nothing to add on the topic just more... Jun 18 2013, 11:05 AM
nathansnathan
Sorry I have nothing to add on the topic just mor... Jun 18 2013, 11:49 AM
Alapone Nathan, thanks for the response. Maybe i am wrong ... Jun 18 2013, 01:42 PM
Racer Chris What you describe during engine warmup is not unus... Jun 19 2013, 04:55 AM
Alapone
What you describe during engine warmup is not unu... Jun 19 2013, 07:35 AM
Racer Chris
Hey RacerChris thanks for the help here. Do you t... Jun 19 2013, 08:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 PM |
