> It's running better..., Much better, Well even!!
Bob L.
post May 4 2013, 05:56 PM
After 10 months of cleaning, freshening and installing my donor motor, among other upgrades and repairs, I finally got the key turned and it started right up. Yippee for me!!
I have not let it run for long (exhaust leak) but it starts right up every time so far. Idle is at about 1850-1900 from a cold start. Is that normal? It's about 80 degrees out.
The main issue is that when I give it gas, it stalls.
I'm sure the timing must need adjusting.
The basics,
76 2.0 with stock D-jet in a 73(originally a 1.7)
EGR and air injection are gone.
Any suggestions where I should start?
It's nice to be able to consult so many experts all at one time.
Thanks all.
Dave_Darling
post May 20 2013, 04:36 PM
914 Idiot
The timing is 27 deg BTDC at 3500 RPM.
In theory, 27 deg BTDC is where the red mark (or just plain notch) on the fan is.
Timing at idle will be much closer to TDC, but not zero.
Set it at 3500 RPM to where the red notch is. Check the Pelican tech article on the subject, it has pictures to help.
--DD
Bob L.   It's running better...   May 4 2013, 05:56 PM
914itis   You may have a vaccum leak , chek for leaks. It sh...   May 4 2013, 06:00 PM
r_towle   Replace all rubber vacuum lines Replace all rubber...   May 4 2013, 06:01 PM
Bob L.   Replace all rubber vacuum lines Replace all rubbe...   May 4 2013, 06:10 PM
Bob L.   Update... Vacuum leak. I could feel the air rush...   May 4 2013, 09:30 PM
Bob L.   O.K. the idle is now on the low side, around 400-5...   May 6 2013, 01:58 PM
Bob L.   I have some new info. I pulled the plugs to reset...   May 11 2013, 01:06 PM
rick 918-S   Replace the cap, rotor and wires. Recheck the valv...   May 11 2013, 03:11 PM
r_towle   Valves and dwell affect timing. Car will run so m...   May 11 2013, 07:19 PM
Bob L.   OK, I replaced the points, Cap and rotor. Wires an...   May 12 2013, 06:51 PM
jmill   Handy dandy chart.   May 12 2013, 08:40 PM
Bob L.   Progress bump. It's been a banner day! I ...   May 19 2013, 07:24 PM
Dave_Darling   The timing is 27 deg BTDC at 3500 RPM. In theory,...   May 20 2013, 04:36 PM
Bob L.   Hi guys, thanks for sticking with me. The tune up ...   May 22 2013, 05:49 PM
Bob L.   I want to check my TPS reports. Is there a ref...   May 24 2013, 11:08 AM
Dave_Darling   Here: http://www.pelicanparts.com/techarticles/9....   May 24 2013, 12:49 PM
Bob L.   Here: http://www.pelicanparts.com/techarticles/9...   May 24 2013, 03:14 PM
Dave_Darling   There's no resistance on this particular part....   May 24 2013, 05:53 PM
Bob L.   There's no resistance on this particular part...   May 24 2013, 08:19 PM
Bob L.   O.K.! The TPS is adjusted. It did h...   May 25 2013, 05:02 PM
914itis   Is the advance in the distributor working properly...   May 25 2013, 05:06 PM
Bob L.   Is the advance in the distributor working properl...   May 25 2013, 05:26 PM
914itis   Connect a spare hose on the advanced and retard po...   May 25 2013, 06:37 PM
dangrouche   In all this, I did not see a mention of checking ...   May 25 2013, 08:03 PM
Bob L.   Itis, I did the sucking test for advance and re...   May 25 2013, 08:53 PM
Bob L.   And another thing... just because the vacuum adv...   May 25 2013, 09:02 PM
914itis   And another thing... just because the vacuum ad...   May 25 2013, 09:11 PM
Bob L.   And another thing... just because the vacuum a...   May 25 2013, 09:17 PM
914itis   [quote name='914itis' post='1869745' date='May 25...   May 25 2013, 09:19 PM
914itis   After testing the trigger points, if you are still...   May 25 2013, 09:04 PM
914itis   I also noticed that you mentioned 76 djet with 73....   May 25 2013, 09:08 PM
Bob L.   I also noticed that you mentioned 76 djet with 73...   May 25 2013, 09:51 PM
Bob L.   And yet another thing... I was searching around a...   May 25 2013, 09:14 PM
914itis   Adjusting the points gap is also know. As dwell, y...   May 25 2013, 09:18 PM
914itis   Reading your previous post, your dwell is at 48, n...   May 25 2013, 09:21 PM
Bob L.   Reading your previous post, your dwell is at 48, ...   May 25 2013, 09:26 PM
914itis   I am not sure about the centrifugal advance, but t...   May 25 2013, 09:31 PM
r_towle   I have found that you can chase an issue like this...   May 26 2013, 07:54 AM
Bob L.   R-towle, I was thinking that myself. I alread...   May 26 2013, 11:58 AM
914itis   It was not a dizzy rebuilt thread, it was the thre...   May 26 2013, 03:48 PM
Bob L.   It was not a dizzy rebuilt thread, it was the thr...   May 26 2013, 04:26 PM
Bob L.   Progress update... I have another dizzy from a 1...   May 27 2013, 03:27 PM
SLITS   Progress update... I have another dizzy from a ...   May 27 2013, 04:32 PM
Dave_Darling   Advance specs scraped from the factory manuals: h...   May 27 2013, 04:27 PM
Bob L.   Thanks Dave. Checking the stampings, it looks lik...   May 27 2013, 06:36 PM
914itis   I have a good working 2.0 dizzy, PM me if you are ...   May 27 2013, 08:09 PM
Bob L.   Update: Finally got the dizzy reconditioned. All...   Jun 8 2013, 06:41 PM
Bob L.   Update: :D :driving: I decided to start f...   Jun 15 2013, 04:53 PM
Cairo94507   Very cool. What a satisfying feel to have resolve...   Jun 16 2013, 07:16 AM
76-914   There is a plastic incased female spade fitting ju...   Jun 16 2013, 08:37 AM
Bob L.   There is a plastic incased female spade fitting j...   Jun 16 2013, 10:52 AM
- Lo-Fi Version Time is now: 9th June 2026 - 02:32 AM
