> 3800 rpm bucking, ok below, ok above - all gears
Axel
post May 20 2013, 05:14 PM
1976 FI 2.0 all stock.
Put it away for the winter, now it stutters like crazy under a load at 3,800 to 4,000 rpm. It stutters and bucks so much that it won't pull itself out of the trouble range. Tachometer stays steady. If I shift to a lower or higher rpm gear, it runs great.
Checked compression, dwell, timing, valve adjustment, spark at plugs, coil resistance...All within range.
Distributor cap, rotor, condensor, and points all look good and have less than 400 miles on them from last year. I can't seem to find any vacuum leaks, but will be replacing all vacuum lines later this week. New plugs last year also...They are still gapped properly, but the 1 through 3 plugs have some dry carbon buildup that is not present on cylinder #4 plug.
Haven't yet checked fuel pressure...Can't seem to find a tap point on the rails.
Haven't changed the fuel filter yet since the last one seems to have trapped itself under the tank...Not an issue, I'll be replacing the lines with stainless from Tangerine when they arrive. Not sure how it can be fuel related since the car runs great outside of this rpm range. Seems to me that it is more likely to be electrical.
Anybody ever run into this issue? Any suggestions would be appreciated.
Axel (IMG:style_emoticons/default/wacko.gif)
TheCabinetmaker
post May 20 2013, 06:24 PM
I drive my car everyday
The traces get worn where they sit at one spot. Like at cruise.
Unplug it. If the stumble goes away, you need a new board.
Axel
post May 20 2013, 06:30 PM
QUOTE(The Cabinetmaker @ May 20 2013, 07:24 PM) *
Actually, that was the first thing I did when I encountered the stuttering last week.
Unplugging the TPS didn't make any noticeable difference.
Axel   3800 rpm bucking   May 20 2013, 05:14 PM
The Cabinetmaker   Your tps board has probably worn or it needs to be...   May 20 2013, 05:55 PM
Axel   Your tps board has probably worn or it needs to b...   May 20 2013, 06:06 PM
The Cabinetmaker   The traces get worn where they sit at one spot. Li...   May 20 2013, 06:24 PM
Axel   The traces get worn where they sit at one spot. L...   May 20 2013, 06:30 PM
motorvated   The traces get worn where they sit at one spot. ...   May 20 2013, 06:47 PM
Axel   [quote name='Axel' post='1866911' date='May 20 20...   May 20 2013, 07:00 PM
mepstein   I had the same problem. Tried everything. fuel lin...   May 20 2013, 06:59 PM
Axel   I had the same problem. Tried everything. fuel li...   May 20 2013, 07:17 PM
gunny   I have the same thing on my 76 2.0 Djet. I have tr...   May 20 2013, 07:20 PM
Axel   I have the same thing on my 76 2.0 Djet. I have t...   May 20 2013, 07:55 PM
mepstein   Same symptoms as mine except some days it would be...   May 20 2013, 08:43 PM
solex   How do the points look. I had the same problem wi...   May 20 2013, 08:52 PM
Axel   Points look clean, dwell is at 50 degrees. Distrib...   May 20 2013, 08:59 PM
solex   Points look clean, dwell is at 50 degrees. Distri...   May 20 2013, 09:06 PM
Axel   Points look clean, dwell is at 50 degrees. Distr...   May 20 2013, 09:19 PM
crash914   do you have another set of trigger points? I have...   May 21 2013, 02:56 AM
Axel   Took apart and cleaned distributor. Replaced coil...   May 22 2013, 04:03 PM
mburkhart   I had this exact same issue in my 74 2.0 for 10 ye...   May 22 2013, 06:41 PM
Axel   I had this exact same issue in my 74 2.0 for 10 y...   May 22 2013, 06:52 PM
Axel   I had this exact same issue in my 74 2.0 for 10 ...   May 23 2013, 01:31 PM
The Cabinetmaker   Well that's great. If it comes back, you now k...   May 23 2013, 01:47 PM
gunny   Which sensor is #2? I have the same issue.   May 23 2013, 07:22 PM
Axel   Which sensor is #2? I have the same issue. I d...   May 24 2013, 10:00 AM
The Cabinetmaker   temp sensor # 2 is the head temp. Only has one wir...   May 24 2013, 02:46 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:27 AM
