| 914_1.8t |
Jul 4 2004, 11:59 AM
Member ![]() ![]() Group: Members Posts: 302 Joined: 3-June 04 From: East Bay Member No.: 2,149 |
I'm doing a Audi 1.8t conversion into my 914. I'm using a complete engine/tranny out of a FWD a4.
I've got the engine/tranny into the 914 and the transmission lines up perfectly with the rear hubs. Now I need to have a set of custome axles made. Anyone know of a place (preferrably in the Bay Area, CA) that can make these for me. I've found a place on the east coast but feel more confortable being able to take my car to the place and letting them do the measurements. Also, I only know of the one place right now. I'd like to know of other places (even east coast) that may do it so that I can compare/shop for the price. Thanks in advance. |
| Chris914n6 |
Jul 7 2004, 12:33 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,526 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
QUOTE(914_1.8t @ Jul 6 2004, 04:13 PM) *Front suspension/brakes/sway bar from 83 Carrera. *Radiator hoses. I still need to call renegade as I hear they have them. Is there anywhere local that I can get these from? Or can I just run 1 1/4" plumbing pipe under car and conncect with radiator hoses? *Mount master clutch cylender directly behind the clutch. Where can I get a brake cable or high stregth rubber hose to run from master cylander to the slave cyl. (located on tranny)? Any Ideas? *Rear springs. I'm thinking 180lbs but wonder if I should be going heavier? SC <-83 or 84-> Carrera. Difference is SC 20mm thick, Carrera 24mm, and spacing on the calipers. A local hose shop should have them. RH likes Gates Green Stripe, but it is soft and tends to sag. My local place (Alternate Hose) carries Dayco, has a wire molded in and is tuff/strong but doesn't like to bend. Same place can make you a clutch hose. If it will fit, run it through the center tunnel where the cable used to be. Check old treads for hydraulic clutch installs. I'm running 180 springs with a stock Carrera front end. It's firm but not rough for me. You should be like 50lbs lighter than my Nissan6 so it's a good starting point. For reference, my car is 2250lbs without me in it. |
914_1.8t Custom axles for my 1.8t 914 Jul 4 2004, 11:59 AM
! Wouldn't it be cheaper and easier to make up a... Jul 4 2004, 12:01 PM
trekkor I need to see a pic of this conversion.
Sounds co... Jul 4 2004, 12:05 PM
914_1.8t
914_1.8t
Dr Evil If you have the 911 hubs that you can use the shor... Jul 4 2004, 12:41 PM
BIGKAT_83 <... Jul 4 2004, 01:14 PM
Mueller Here you go:
SmartRacing Products, custom axles
... Jul 4 2004, 02:37 PM
Mueller oh yea, where are you located? I'd like to see... Jul 4 2004, 02:38 PM
914_1.8t
Chris914n6 Count the splines and measure the diameter on the ... Jul 4 2004, 07:59 PM
Brett W Welding Axels, bad idea. BTDT got the pile of bro... Jul 5 2004, 09:03 AM
andys 914 1.8t,
What year A4 are you swapping? AFAIK, t... Jul 6 2004, 02:09 PM
Dave Bell What Doctor Evil said
The 911 axles are already s... Jul 6 2004, 03:11 PM
914_1.8t I'll conunt the splines and take some measurem... Jul 6 2004, 06:13 PM
914_1.8t Also, in regards to the rear springs. Can I use o... Jul 6 2004, 06:19 PM
Mueller I'll be up in Hayward this evening around 9 or... Jul 6 2004, 07:59 PM
Mueller depends on a few things:
the OD of the shock, wil... Jul 6 2004, 08:05 PM
spare time toys Is this engine a side winder or front to back set ... Jul 7 2004, 02:36 PM
Mueller front to back set up.........much better than the ... Jul 7 2004, 02:47 PM
914_1.8t
corpselaurel Finally someone doing the same conversion as me. ... Jul 7 2004, 07:16 PM
Scott Carlberg it's interesting (ok, maybe just to me! ... Jul 7 2004, 10:13 PM
corpselaurel the article was my inspiration, though I won't... Jul 8 2004, 01:04 PM
914_1.8t ![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 10:09 PM |
