| billh1963 |
May 21 2013, 07:20 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
If you were to install a carb'ed 911 6 in a 914, other than oil pressure and oil temperature what other engine gauges would you install? What would be important? CHT for each cylinder? Anything else? Thoughts?
| brant |
May 21 2013, 07:30 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,204 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
an alternator warning light
loose a fan belt and the amount of time to shut it down before toasting the motor is about the same as lack of oil pressure. |
billh1963 What gauges would you install for an air cooled 6? May 21 2013, 07:20 PM
billh1963
loose a fan belt and... May 21 2013, 07:44 PM
brant I use these for my oil pressure light and alternat... May 21 2013, 07:47 PM
Mark Henry
I use these for my oil pressure light and alterna... May 22 2013, 06:04 AM
pcar916
Anyone have a nice bright alternative and maybe f... May 22 2013, 06:29 AM
billh1963 Those would get my attention! May 21 2013, 07:54 PM
shoguneagle I just like gauges so I have the normal ones assoc... May 21 2013, 11:56 PM
SUNAB914 What you doing Bill? Where are these -6 questions ... May 22 2013, 05:45 AM
billh1963
What you doing Bill? Where are these -6 questions... May 22 2013, 06:00 AM
GeorgeRud Radio Shack has some simple, bright 12 volt indica... May 22 2013, 06:22 AM
Mark Henry
Radio Shack has some simple, bright 12 volt indic... May 22 2013, 06:27 AM
Eric_Shea Stock(ish) has oil pressure and alternator lights:... May 22 2013, 10:55 AM
billh1963 I like this gauge below. I just think that as expe... May 22 2013, 01:08 PM
JmuRiz Yep, that's the way to go, has the low fuel li... May 22 2013, 02:26 PM
timothy_nd28 Forgive me as I'm not familiar with this type ... May 22 2013, 02:35 PM
brant if the fan belt throws... the engine cooling fan ... May 22 2013, 02:38 PM
Eric_Shea Never liked the triple gauges I've seen becaus... May 22 2013, 02:43 PM
patssle $57 dollars for a VDO fuel gauge 2 1/16... May 22 2013, 05:00 PM
Dave_Darling And you can separate out the low fuel warning ligh... May 22 2013, 05:10 PM
Eric_Shea
And you can separate out the low fuel warning lig... May 22 2013, 08:13 PM
pcar916 Mine is similar to Eric's except with a differ... May 22 2013, 05:18 PM
Dave_Darling Yes, but if you put the fuel gauge where the radio... May 22 2013, 10:33 PM
7TPorsh RE: What gauges would you install for an air cooled 6? May 22 2013, 11:41 PM
eitnurg What about converting the boost pressure gauge on ... May 23 2013, 01:17 AM
billh1963
What about converting the boost pressure gauge on... May 23 2013, 05:45 AM
Dave_Darling
What about converting the boost pressure gauge on... May 23 2013, 11:48 AM
Eric_Shea :agree: Call Hartmut at Palo Alto and ask. You... May 23 2013, 07:05 AM
JmuRiz Maybe I'll have to contact to see if it's ... May 23 2013, 08:05 AM
stugray
Brant, if the belt comes off the alternator stop... May 23 2013, 08:20 AM
brant
Brant, if the belt comes off the alternator sto... May 23 2013, 11:54 AM
9146986 I'm a big fan of using the 930 tach and having... May 23 2013, 08:40 AM
SirAndy What gauges would you install for an air cooled 6?... May 23 2013, 12:38 PM
eitnurg
True up to and including the 3.2. But ISTR on my... May 23 2013, 12:44 PM
brant
True up to and including the 3.2. But ISTR on m... May 23 2013, 01:04 PM
Racer Chris
some kind of warning light on the dash lit up i... May 24 2013, 08:57 AM
pcar916
... one drives the alternator, one drives the fan... May 23 2013, 08:31 PM
stugray
Sorry, forgot the topic was specific to 6 cyls.
... May 24 2013, 08:35 AM
Mark Henry I'm thinking of making this into a combo gauge... May 24 2013, 02:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:27 AM |
