Trans Temps, What are people seeing? |
Matt Romanowski |
Apr 15 2013, 06:03 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
This weekend after a 40 minute stint on the track, we saw our transmission temps getting to 247F. That is on a day were it was about 45F ambient and we had the pump and cooler running.
Doing some research, the answers I've heard on safe temperatures are all over. The oil is good to 300F according to the manufacturer and some folks say they run there, but that seems really hot. Most folks say they like to be around 225F. We just rebuilt the transmission and set the R+P to the factory backlash setting of .007", but we're going to open the transmission up and loosen things up a bit. |
brant |
May 22 2013, 12:55 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
just another data point:
I took my cooler set up which normally runs a 3 inch flexible tubing to the cooler from an underbody aluminum scoop I had built.... Over last weekend, I disconnected the scoop and zip tied to the hose to the drivers side window roll bar. not protruding into the air stream but close to the edge of where the side window would be... so definitely close to the air stream, but no scoop nothing effective in the air stream 20degree F drop in trans oil temps the highest I saw on a moderate day was 205 - 206F range |
Lo-Fi Version | Time is now: 8th June 2024 - 03:21 PM |
