> What gauges would you install for an air cooled 6?
billh1963
post May 21 2013, 07:20 PM
Car Hoarder!
If you were to install a carb'ed 911 6 in a 914, other than oil pressure and oil temperature what other engine gauges would you install? What would be important? CHT for each cylinder? Anything else? Thoughts?
timothy_nd28
post May 22 2013, 02:35 PM
Forgive me as I'm not familiar with this type of engine, why exactly is it imperative to have a warning light for the alternator?
billh1963   What gauges would you install for an air cooled 6?   May 21 2013, 07:20 PM
brant   an alternator warning light loose a fan belt and ...   May 21 2013, 07:30 PM
billh1963   an alternator warning light loose a fan belt and...   May 21 2013, 07:44 PM
brant   I use these for my oil pressure light and alternat...   May 21 2013, 07:47 PM
Mark Henry   I use these for my oil pressure light and alterna...   May 22 2013, 06:04 AM
pcar916   Anyone have a nice bright alternative and maybe f...   May 22 2013, 06:29 AM
billh1963   Those would get my attention!   May 21 2013, 07:54 PM
shoguneagle   I just like gauges so I have the normal ones assoc...   May 21 2013, 11:56 PM
SUNAB914   What you doing Bill? Where are these -6 questions ...   May 22 2013, 05:45 AM
billh1963   What you doing Bill? Where are these -6 questions...   May 22 2013, 06:00 AM
GeorgeRud   Radio Shack has some simple, bright 12 volt indica...   May 22 2013, 06:22 AM
Mark Henry   Radio Shack has some simple, bright 12 volt indic...   May 22 2013, 06:27 AM
Eric_Shea   Stock(ish) has oil pressure and alternator lights:...   May 22 2013, 10:55 AM
billh1963   I like this gauge below. I just think that as expe...   May 22 2013, 01:08 PM
JmuRiz   Yep, that's the way to go, has the low fuel li...   May 22 2013, 02:26 PM
timothy_nd28   Forgive me as I'm not familiar with this type ...   May 22 2013, 02:35 PM
brant   if the fan belt throws... the engine cooling fan ...   May 22 2013, 02:38 PM
Eric_Shea   Never liked the triple gauges I've seen becaus...   May 22 2013, 02:43 PM
patssle   $57 dollars for a VDO fuel gauge 2 1/16...   May 22 2013, 05:00 PM
Dave_Darling   And you can separate out the low fuel warning ligh...   May 22 2013, 05:10 PM
Eric_Shea   And you can separate out the low fuel warning lig...   May 22 2013, 08:13 PM
pcar916   Mine is similar to Eric's except with a differ...   May 22 2013, 05:18 PM
Dave_Darling   Yes, but if you put the fuel gauge where the radio...   May 22 2013, 10:33 PM
7TPorsh   RE: What gauges would you install for an air cooled 6?   May 22 2013, 11:41 PM
eitnurg   What about converting the boost pressure gauge on ...   May 23 2013, 01:17 AM
billh1963   What about converting the boost pressure gauge on...   May 23 2013, 05:45 AM
Dave_Darling   What about converting the boost pressure gauge on...   May 23 2013, 11:48 AM
Eric_Shea   :agree: Call Hartmut at Palo Alto and ask. You...   May 23 2013, 07:05 AM
JmuRiz   Maybe I'll have to contact to see if it's ...   May 23 2013, 08:05 AM
stugray   Brant, if the belt comes off the alternator stop...   May 23 2013, 08:20 AM
brant   Brant, if the belt comes off the alternator sto...   May 23 2013, 11:54 AM
9146986   I'm a big fan of using the 930 tach and having...   May 23 2013, 08:40 AM
SirAndy   What gauges would you install for an air cooled 6?...   May 23 2013, 12:38 PM
eitnurg   True up to and including the 3.2. But ISTR on my...   May 23 2013, 12:44 PM
brant   True up to and including the 3.2. But ISTR on m...   May 23 2013, 01:04 PM
Racer Chris   some kind of warning light on the dash lit up i...   May 24 2013, 08:57 AM
pcar916   ... one drives the alternator, one drives the fan...   May 23 2013, 08:31 PM
stugray   Sorry, forgot the topic was specific to 6 cyls. ...   May 24 2013, 08:35 AM
Mark Henry   I'm thinking of making this into a combo gauge...   May 24 2013, 02:29 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:28 AM
