> What gauges would you install for an air cooled 6?
billh1963
post May 21 2013, 07:20 PM
Car Hoarder!
If you were to install a carb'ed 911 6 in a 914, other than oil pressure and oil temperature what other engine gauges would you install? What would be important? CHT for each cylinder? Anything else? Thoughts?
patssle
post May 22 2013, 05:00 PM
$57 dollars for a VDO fuel gauge 2 1/16" 0-70 ohm (70 being empty) from North Hollywood Speedometer that fits right in the center console (if you have one). No modifying the oil gauge that replaces the /4 fuel/temp gauge.
billh1963   What gauges would you install for an air cooled 6?   May 21 2013, 07:20 PM
brant   an alternator warning light loose a fan belt and ...   May 21 2013, 07:30 PM
billh1963   an alternator warning light loose a fan belt and...   May 21 2013, 07:44 PM
brant   I use these for my oil pressure light and alternat...   May 21 2013, 07:47 PM
Mark Henry   I use these for my oil pressure light and alterna...   May 22 2013, 06:04 AM
pcar916   Anyone have a nice bright alternative and maybe f...   May 22 2013, 06:29 AM
billh1963   Those would get my attention!   May 21 2013, 07:54 PM
shoguneagle   I just like gauges so I have the normal ones assoc...   May 21 2013, 11:56 PM
SUNAB914   What you doing Bill? Where are these -6 questions ...   May 22 2013, 05:45 AM
billh1963   What you doing Bill? Where are these -6 questions...   May 22 2013, 06:00 AM
GeorgeRud   Radio Shack has some simple, bright 12 volt indica...   May 22 2013, 06:22 AM
Mark Henry   Radio Shack has some simple, bright 12 volt indic...   May 22 2013, 06:27 AM
Eric_Shea   Stock(ish) has oil pressure and alternator lights:...   May 22 2013, 10:55 AM
billh1963   I like this gauge below. I just think that as expe...   May 22 2013, 01:08 PM
JmuRiz   Yep, that's the way to go, has the low fuel li...   May 22 2013, 02:26 PM
timothy_nd28   Forgive me as I'm not familiar with this type ...   May 22 2013, 02:35 PM
brant   if the fan belt throws... the engine cooling fan ...   May 22 2013, 02:38 PM
Eric_Shea   Never liked the triple gauges I've seen becaus...   May 22 2013, 02:43 PM
patssle   $57 dollars for a VDO fuel gauge 2 1/16...   May 22 2013, 05:00 PM
Dave_Darling   And you can separate out the low fuel warning ligh...   May 22 2013, 05:10 PM
Eric_Shea   And you can separate out the low fuel warning lig...   May 22 2013, 08:13 PM
pcar916   Mine is similar to Eric's except with a differ...   May 22 2013, 05:18 PM
Dave_Darling   Yes, but if you put the fuel gauge where the radio...   May 22 2013, 10:33 PM
7TPorsh   RE: What gauges would you install for an air cooled 6?   May 22 2013, 11:41 PM
eitnurg   What about converting the boost pressure gauge on ...   May 23 2013, 01:17 AM
billh1963   What about converting the boost pressure gauge on...   May 23 2013, 05:45 AM
Dave_Darling   What about converting the boost pressure gauge on...   May 23 2013, 11:48 AM
Eric_Shea   :agree: Call Hartmut at Palo Alto and ask. You...   May 23 2013, 07:05 AM
JmuRiz   Maybe I'll have to contact to see if it's ...   May 23 2013, 08:05 AM
stugray   Brant, if the belt comes off the alternator stop...   May 23 2013, 08:20 AM
brant   Brant, if the belt comes off the alternator sto...   May 23 2013, 11:54 AM
9146986   I'm a big fan of using the 930 tach and having...   May 23 2013, 08:40 AM
SirAndy   What gauges would you install for an air cooled 6?...   May 23 2013, 12:38 PM
eitnurg   True up to and including the 3.2. But ISTR on my...   May 23 2013, 12:44 PM
brant   True up to and including the 3.2. But ISTR on m...   May 23 2013, 01:04 PM
Racer Chris   some kind of warning light on the dash lit up i...   May 24 2013, 08:57 AM
pcar916   ... one drives the alternator, one drives the fan...   May 23 2013, 08:31 PM
stugray   Sorry, forgot the topic was specific to 6 cyls. ...   May 24 2013, 08:35 AM
Mark Henry   I'm thinking of making this into a combo gauge...   May 24 2013, 02:29 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:28 AM
