| dfelz |
May 22 2013, 05:41 PM
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California
I am going to a 911 dash and saw awhile back a members picture where they used multi pin connectors to simplify things and i really like the idea and want to implement it myself in my conversion and other spots like the turn signal buckets. I have looked on digi-key but quickly get lost in the lingo used in their catalog since i am not super familiar with the electrical side of things. Can someone please help me out with this one. will need the male and matching female connectors along with the proper type of male and female terminals used that are soldered to the wires.
thanks in advance!!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Attached image(s)
| Cap'n Krusty |
May 22 2013, 06:44 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
You mention "soldered". Soldering is NOT recommended for automotive applications, and should be done only by trained and experienced electrical experts. Really. The industry standard for connecting terminals to wires is crimping, which should be done using the proper tools and fixtures. Not that difficult, although the proper tools might set you back some pretty serious coin. Be sure to get the correct terminals based on the wire gauges you plan to use. BTW, European wires aren't sized using AWG nomenclature. They're metric.
Have fun! Looks like an interesting project, one worth doing. The Cap'n |
dfelz Multi pin connectors May 22 2013, 05:41 PM
kg6dxn Those look like Molex brand. You would have to mea... May 22 2013, 06:08 PM
AE354803 Check out McMaster ( http://www.mcmaster.com/#con... May 22 2013, 06:14 PM
dfelz Awesome! thank you gentlemen :beer2:
I dont... May 22 2013, 06:29 PM
AE354803 I would get the 250V non space saver, the 0.093... May 22 2013, 06:39 PM
dfelz I was just about to post a double reply saying i j... May 22 2013, 06:42 PM
dfelz Thanks Cap'n, I was unaware that solder should... May 22 2013, 06:52 PM
SirAndy Can someone please help me out with this one.
Sinc... May 22 2013, 07:43 PM
Matt Romanowski Go with Deutsch connectors. The best prices I... May 22 2013, 08:11 PM
Jeff Bowlsby Adding the connectors adds more potential location... May 22 2013, 08:15 PM
kg6dxn Crimping and soldering is a great way to go if you... May 22 2013, 08:44 PM
jeffdon
Crimping and soldering is a great way to go if yo... May 23 2013, 11:59 AM
dfelz Thanks for the input Mike, i will definitely take ... May 22 2013, 09:23 PM
Dave_Darling Don't forget to get the correct de-pinning too... May 22 2013, 10:28 PM
dfelz Good point Dave. At $50 for the pair of inser... May 22 2013, 10:42 PM
Dave_Darling
Good point Dave. At $50 for the pair of inse... May 23 2013, 11:42 AM
r_towle Just a suggestion, because I like to be able to fi... May 23 2013, 09:36 AM
dfelz Thanks Rich, I will have to check out their select... May 23 2013, 10:04 AM
McMark Here's the PN for the ones pictured above. I... May 23 2013, 10:24 AM
kg6dxn I don't need an insertion tool for Molex. They... May 23 2013, 06:32 PM
Matt Romanowski Check for the cycle limits on the connectors you a... May 23 2013, 08:09 PM
stugray Capn,
Just curious why you say that.
I use the... May 24 2013, 10:00 PM
Dave_Darling Probably because most of us can't solder for s... May 24 2013, 10:26 PM
kg6dxn
Probably because most of us can't solder for ... May 25 2013, 09:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 AM |
