> Heat Exchanger to head nut torque
jmalone
post May 22 2013, 09:53 PM
Can anyone confirm the torque figures for the heat exchanger to head nuts? I have initial torque at 7.3 ft/lb and final torque at 24.5 ft/lb.
nathansnathan
post May 23 2013, 09:19 AM
For a bus they give it 16 (oops, 14 )foot lbs. They are known to loosen so it's recommended to re-torque them after running it once.
jmalone   Heat Exchanger to head nut torque   May 22 2013, 09:53 PM
bandjoey   Too late tonight to look it up and someone will ge...   May 22 2013, 11:41 PM
Jeff Bowlsby   The torque value is not printed anywhere. Use onl...   May 23 2013, 05:01 AM
jmalone   The torque value is not printed anywhere. Use on...   May 23 2013, 09:17 AM
CG-914   The torque value is not printed anywhere. Use on...   May 25 2013, 10:45 PM
nathansnathan   For a bus they give it 16 (oops, 14 )foot lbs. The...   May 23 2013, 09:19 AM
nathansnathan   dbl posted   May 23 2013, 09:19 AM
stugray   I just went through this entire process: 1 - repl...   May 23 2013, 09:40 AM
nathansnathan   I just went through this entire process: 1 - rep...   May 23 2013, 11:17 AM
Tom   By using anti-seize on the threads, you have now m...   May 23 2013, 12:12 PM
cary   By using anti-seize on the threads, you have now ...   May 24 2013, 06:05 AM
Marty Yeoman   Last time I did this I used McMark's patented ...   May 23 2013, 01:13 PM
Kraftwerk   Last time I did this I used McMark's patented...   May 23 2013, 02:02 PM
The Cabinetmaker   Last time I did this I used McMark's patente...   Oct 23 2013, 02:14 PM
porsche913b_sp   Last time I did this I used McMark's patented...   May 23 2013, 11:08 PM
euro911   Last time I did this I used McMark's patented ...   Oct 22 2013, 11:13 PM
Haudiosolutions   Thought I'd toss in a find, I too just went th...   May 24 2013, 06:45 PM
CG-914   :popcorn:   May 24 2013, 11:01 PM
Bob L.   I did find this... http://www.tunacan.net/t4/refer...   May 25 2013, 11:24 PM
bandjoey   Why do you anneal? What does Annealing do to the ...   Oct 23 2013, 08:31 AM
Dave_Darling   Annealing makes the copper "dead soft". ...   Oct 23 2013, 08:54 AM
jimkelly   I've seen a thread where the guy took a long f...   Oct 23 2013, 03:16 PM
rhodyguy   light, even dressing with a big bastard file is pr...   Oct 24 2013, 06:10 AM
nathansnathan   Also, you have to take off a much from the tops of...   Oct 24 2013, 06:39 AM
rhodyguy   usually the first pass with the file shows how muc...   Oct 24 2013, 06:51 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:28 PM
