| billh1963 |
May 21 2013, 07:20 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
If you were to install a carb'ed 911 6 in a 914, other than oil pressure and oil temperature what other engine gauges would you install? What would be important? CHT for each cylinder? Anything else? Thoughts?
| stugray |
May 23 2013, 08:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE if the fan belt throws... the engine cooling fan stops Brant, if the belt comes off the alternator stops spinning, but the fan keeps going. However you are still right. If your fan comes completely off the crank (as we saw at the races last weekend,), the ALT light will tell you that there is something wrong immediately ;-) That saved at least one engine in the last week. Stu |
| brant |
May 23 2013, 11:54 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,204 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
QUOTE if the fan belt throws... the engine cooling fan stops Brant, if the belt comes off the alternator stops spinning, but the fan keeps going. However you are still right. If your fan comes completely off the crank (as we saw at the races last weekend,), the ALT light will tell you that there is something wrong immediately ;-) That saved at least one engine in the last week. Stu true for the 4cylinder but on the 6cylinder the belt drives the fan |
billh1963 What gauges would you install for an air cooled 6? May 21 2013, 07:20 PM
brant an alternator warning light
loose a fan belt and ... May 21 2013, 07:30 PM
billh1963
loose a fan belt and... May 21 2013, 07:44 PM
brant I use these for my oil pressure light and alternat... May 21 2013, 07:47 PM
Mark Henry
I use these for my oil pressure light and alterna... May 22 2013, 06:04 AM
pcar916
Anyone have a nice bright alternative and maybe f... May 22 2013, 06:29 AM
billh1963 Those would get my attention! May 21 2013, 07:54 PM
shoguneagle I just like gauges so I have the normal ones assoc... May 21 2013, 11:56 PM
SUNAB914 What you doing Bill? Where are these -6 questions ... May 22 2013, 05:45 AM
billh1963
What you doing Bill? Where are these -6 questions... May 22 2013, 06:00 AM
GeorgeRud Radio Shack has some simple, bright 12 volt indica... May 22 2013, 06:22 AM
Mark Henry
Radio Shack has some simple, bright 12 volt indic... May 22 2013, 06:27 AM
Eric_Shea Stock(ish) has oil pressure and alternator lights:... May 22 2013, 10:55 AM
billh1963 I like this gauge below. I just think that as expe... May 22 2013, 01:08 PM
JmuRiz Yep, that's the way to go, has the low fuel li... May 22 2013, 02:26 PM
timothy_nd28 Forgive me as I'm not familiar with this type ... May 22 2013, 02:35 PM
brant if the fan belt throws... the engine cooling fan ... May 22 2013, 02:38 PM
Eric_Shea Never liked the triple gauges I've seen becaus... May 22 2013, 02:43 PM
patssle $57 dollars for a VDO fuel gauge 2 1/16... May 22 2013, 05:00 PM
Dave_Darling And you can separate out the low fuel warning ligh... May 22 2013, 05:10 PM
Eric_Shea
And you can separate out the low fuel warning lig... May 22 2013, 08:13 PM
pcar916 Mine is similar to Eric's except with a differ... May 22 2013, 05:18 PM
Dave_Darling Yes, but if you put the fuel gauge where the radio... May 22 2013, 10:33 PM
7TPorsh RE: What gauges would you install for an air cooled 6? May 22 2013, 11:41 PM
eitnurg What about converting the boost pressure gauge on ... May 23 2013, 01:17 AM
billh1963
What about converting the boost pressure gauge on... May 23 2013, 05:45 AM
Dave_Darling
What about converting the boost pressure gauge on... May 23 2013, 11:48 AM
Eric_Shea :agree: Call Hartmut at Palo Alto and ask. You... May 23 2013, 07:05 AM
JmuRiz Maybe I'll have to contact to see if it's ... May 23 2013, 08:05 AM
9146986 I'm a big fan of using the 930 tach and having... May 23 2013, 08:40 AM
SirAndy What gauges would you install for an air cooled 6?... May 23 2013, 12:38 PM
eitnurg
True up to and including the 3.2. But ISTR on my... May 23 2013, 12:44 PM
brant
True up to and including the 3.2. But ISTR on m... May 23 2013, 01:04 PM
Racer Chris
some kind of warning light on the dash lit up i... May 24 2013, 08:57 AM
pcar916
... one drives the alternator, one drives the fan... May 23 2013, 08:31 PM
stugray
Sorry, forgot the topic was specific to 6 cyls.
... May 24 2013, 08:35 AM
Mark Henry I'm thinking of making this into a combo gauge... May 24 2013, 02:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:28 AM |
