| dfelz |
May 22 2013, 05:41 PM
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California
I am going to a 911 dash and saw awhile back a members picture where they used multi pin connectors to simplify things and i really like the idea and want to implement it myself in my conversion and other spots like the turn signal buckets. I have looked on digi-key but quickly get lost in the lingo used in their catalog since i am not super familiar with the electrical side of things. Can someone please help me out with this one. will need the male and matching female connectors along with the proper type of male and female terminals used that are soldered to the wires.
thanks in advance!!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Attached image(s)
| Mike Bellis |
May 22 2013, 08:44 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Crimping and soldering is a great way to go if you know how to solder correctly. If corrosion is a worry, use dielectric grease.
When soldering, there is a fine balance of heat and flow. Too much heat and the wire insulation melts. A high heat iron and short working time is recommended. Make sure you don't get too much solder on the connection or it may impact the locking tab on the connector. I soldered every connection on my conversion. No problems and the crimp will never come loose. BTW, I went to soldering school in the Marine Corps. 2 long weeks of soldering 8 hours per day. Fun... (IMG:style_emoticons/default/dry.gif) |
| jeffdon |
May 23 2013, 11:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Crimping and soldering is a great way to go if you know how to solder correctly. If corrosion is a worry, use dielectric grease. When soldering, there is a fine balance of heat and flow. Too much heat and the wire insulation melts. A high heat iron and short working time is recommended. Make sure you don't get too much solder on the connection or it may impact the locking tab on the connector. I soldered every connection on my conversion. No problems and the crimp will never come loose. BTW, I went to soldering school in the Marine Corps. 2 long weeks of soldering 8 hours per day. Fun... (IMG:style_emoticons/default/dry.gif) Combat soldering! Seriously, I took a series of electronic tech classes at College of San Mateo back in the 80s, and we did a few weeks just on soldering. The instructor had been through the NASA soldering school, and it was actually rather interesting. But not for 8 hrs a day! |
dfelz Multi pin connectors May 22 2013, 05:41 PM
kg6dxn Those look like Molex brand. You would have to mea... May 22 2013, 06:08 PM
AE354803 Check out McMaster ( http://www.mcmaster.com/#con... May 22 2013, 06:14 PM
dfelz Awesome! thank you gentlemen :beer2:
I dont... May 22 2013, 06:29 PM
AE354803 I would get the 250V non space saver, the 0.093... May 22 2013, 06:39 PM
dfelz I was just about to post a double reply saying i j... May 22 2013, 06:42 PM
Cap'n Krusty You mention "soldered". Soldering is NO... May 22 2013, 06:44 PM
dfelz Thanks Cap'n, I was unaware that solder should... May 22 2013, 06:52 PM
SirAndy Can someone please help me out with this one.
Sinc... May 22 2013, 07:43 PM
Matt Romanowski Go with Deutsch connectors. The best prices I... May 22 2013, 08:11 PM
Jeff Bowlsby Adding the connectors adds more potential location... May 22 2013, 08:15 PM
dfelz Thanks for the input Mike, i will definitely take ... May 22 2013, 09:23 PM
Dave_Darling Don't forget to get the correct de-pinning too... May 22 2013, 10:28 PM
dfelz Good point Dave. At $50 for the pair of inser... May 22 2013, 10:42 PM
Dave_Darling
Good point Dave. At $50 for the pair of inse... May 23 2013, 11:42 AM
r_towle Just a suggestion, because I like to be able to fi... May 23 2013, 09:36 AM
dfelz Thanks Rich, I will have to check out their select... May 23 2013, 10:04 AM
McMark Here's the PN for the ones pictured above. I... May 23 2013, 10:24 AM
kg6dxn I don't need an insertion tool for Molex. They... May 23 2013, 06:32 PM
Matt Romanowski Check for the cycle limits on the connectors you a... May 23 2013, 08:09 PM
stugray Capn,
Just curious why you say that.
I use the... May 24 2013, 10:00 PM
Dave_Darling Probably because most of us can't solder for s... May 24 2013, 10:26 PM
kg6dxn
Probably because most of us can't solder for ... May 25 2013, 09:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 AM |
