| jmalone |
May 22 2013, 09:53 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California
Can anyone confirm the torque figures for the heat exchanger to head nuts? I have initial torque at 7.3 ft/lb and final torque at 24.5 ft/lb.
| Tom |
May 23 2013, 12:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
By using anti-seize on the threads, you have now made the dry torque figures no longer applicable. Google wet versus dry torque numbers to understand. Example, a dry torque required of 20 ftlbs being applied to a wet thread will yield about 25-28 ftlbs of actual torque, resulting in an over-torqued fastener.
Better yet, just do as Jeff said and torque only until the HE's seal. Tom |
jmalone Heat Exchanger to head nut torque May 22 2013, 09:53 PM
bandjoey Too late tonight to look it up and someone will ge... May 22 2013, 11:41 PM
Jeff Bowlsby The torque value is not printed anywhere. Use onl... May 23 2013, 05:01 AM
jmalone
The torque value is not printed anywhere. Use on... May 23 2013, 09:17 AM
CG-914
The torque value is not printed anywhere. Use on... May 25 2013, 10:45 PM
nathansnathan For a bus they give it 16 (oops, 14 )foot lbs. The... May 23 2013, 09:19 AM
nathansnathan dbl posted May 23 2013, 09:19 AM
stugray I just went through this entire process:
1 - repl... May 23 2013, 09:40 AM
nathansnathan
1 - rep... May 23 2013, 11:17 AM
cary
By using anti-seize on the threads, you have now ... May 24 2013, 06:05 AM
Marty Yeoman Last time I did this I used McMark's patented ... May 23 2013, 01:13 PM
Kraftwerk
Last time I did this I used McMark's patented... May 23 2013, 02:02 PM
The Cabinetmaker
Last time I did this I used McMark's patente... Oct 23 2013, 02:14 PM
porsche913b_sp
Last time I did this I used McMark's patented... May 23 2013, 11:08 PM
euro911 Last time I did this I used McMark's patented ... Oct 22 2013, 11:13 PM
Haudiosolutions Thought I'd toss in a find, I too just went th... May 24 2013, 06:45 PM
CG-914 :popcorn: May 24 2013, 11:01 PM
Bob L. I did find this...
http://www.tunacan.net/t4/refer... May 25 2013, 11:24 PM
bandjoey Why do you anneal? What does Annealing do to the ... Oct 23 2013, 08:31 AM
Dave_Darling Annealing makes the copper "dead soft". ... Oct 23 2013, 08:54 AM
jimkelly I've seen a thread where the guy took a long f... Oct 23 2013, 03:16 PM
rhodyguy light, even dressing with a big bastard file is pr... Oct 24 2013, 06:10 AM
nathansnathan Also, you have to take off a much from the tops of... Oct 24 2013, 06:39 AM
rhodyguy usually the first pass with the file shows how muc... Oct 24 2013, 06:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:28 PM |
