| Mueller |
Jul 7 2004, 09:23 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
We don't read about people shifting into the wrong gear too often which ends in costly repairs, but when we do hear about it, it gives everyone a sick feeling knowing that big money is about to be spent.
Now it seems it wouldn't be too difficult to have a "box" that monitors engine RPM as well as what gear the driver is in and MPH. Of course the "box" is going to have to have some logic control with user inputs for different variables. Basicly what we want to do is have the "box" tied to an electrical/mechanical device that will not allow you to put the car into a gear which the "box" has deemed unsafe. So if you are in 4th @ 6500 and want to go to 3rd which will raise the rpms to 7000 (borderline redline) the "box" will "okay" the gear choice and not interfer....well, due to some odd reason, the driver picks 2nd gear instead, the "box" knows that 7500 rpm is way too high and it gives a signal to the electrical/mechanical device and "blocks" the gear selection. Now the only way the driver can put the car into a gear is: Stay in 4th or, shift into 5th or slow the car down enough so that the road speed will match the RPM/gear/MPH safety combination which is the "box" will be programmed for. This is nothing new, Porsche used this logic on thier PDK transmission and RUF had this for his clutchpedal-less manual shifting cars.AFAIK, no one has this as an "add-on" device or to be used with a clutch pedal |
| JWest |
Jul 7 2004, 10:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,666 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None
QUOTE(lapuwali @ Jul 7 2004, 11:28 AM) Imagine, instead of the synchro/slider/dog gear system, you had a set of small hydraulically actuated multiplate clutches (hydraulic fluid acting directly on a pressure plate inside a housing splined to the shaft, just as the slider is). That just sounds like a run-of-the-mill automatic transmission, just made more complex by trying to package it with normal gears rather than planetary gear sets. |
Mueller Engine protection device??? electrical "box" Jul 7 2004, 09:23 AM
Mueller another brain fart: instead of having the device p... Jul 7 2004, 09:33 AM
Aaron Cox one word: UNSAFE
you cannot prevent someone from ... Jul 7 2004, 09:36 AM
Mueller "For competion use only"
does that make you feel ... Jul 7 2004, 09:49 AM
ss6 If you're going to be making a doodad that blo... Jul 7 2004, 10:08 AM
Mueller SS6, trust me, I've thought about it.......the... Jul 7 2004, 10:14 AM
airsix Mueller, check your PM's NOW! Jul 7 2004, 10:15 AM
lapuwali I can't think of a single instance where downs... Jul 7 2004, 10:28 AM
Hi_Fi_Guy The safest system I can think of is a Sequential A... Jul 7 2004, 10:33 AM
James Adams ... Jul 7 2004, 11:07 AM
VegasRacer I've got a friend who races a 912. He blew his... Jul 7 2004, 11:32 AM
McMark It would be pretty easy to stop a hydraulic clutch... Jul 7 2004, 11:43 AM
iamchappy It seems like it would be fairly simple to make a ... Jul 7 2004, 12:11 PM
James Adams ... Jul 7 2004, 12:41 PM
lapuwali
James Adams <... Jul 7 2004, 12:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 06:42 PM |
