| Krieger |
May 24 2013, 09:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,860 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Directions say fuel level between top two lines. Why are there four lines? Or is it supposed to be set in the middle area between the two pairs of lines? Is idle speed sufficient?
| J P Stein |
May 24 2013, 09:51 AM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
The meniscus is supposed to go within the upper 2 lines, IMO.
I never had the guts to have the motor running.....too risky when working alone I set them with the fuel pressure ON, engine OFF.....worked out OK. |
Krieger Adjusting float level weber 3 bbl carbs with PMO tool May 24 2013, 09:40 AM
Krieger Ahh! I did rotate it before I posted. I thin... May 24 2013, 09:44 AM
mskala Yes top 2 lines, and the motor must be running. May 24 2013, 10:12 AM
Krieger Thanks Mark, it just seems like such a narrow ran... May 24 2013, 10:27 AM
mskala
Thanks Mark, it just seems like such a narrow ra... May 24 2013, 11:03 AM
Krieger Great info! Thank you May 24 2013, 12:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:44 AM |
