| r3dplanet |
May 23 2013, 08:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Peeps,
Allow me to begin by stating that I've never done this before. Well, not for twenty years anyway when I was an undergrad working in a furniture restoration shop as a college job. I bought one of Mikey914's cool new fiberglass door panel and vinyl kits as seen here: http://www.914world.com/bbs2/index.php?sho...10198&st=20 For additional reference: http://www.914world.com/bbs2/index.php?sho...=54608&st=0 Armed with this how-to, I'm off to work in an empty bedroom because it's Portland, WCR is three weeks away, and it's pouring rain outside. I admit I'm lost without a stapler. There are two things I don't know how to do. I have the aluminum strip riveted in and the bolster is nicely aligned with positive lock. But I don't know exactly how to attach the vinyl on the backside without a stapler. Sure there's contact cement, but it doesn't seem like that would work conveniently because you can't just inch your way along and keep the vinyl nice and and tight around the corners. Any ideas from those smarter than I? -marcus Attached image(s)
| nathansnathan |
May 24 2013, 10:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I have been wondering about this for awhile, as I have a fiberglass back pad core that I want to transplant the original vinyl and padding to.
| worn |
May 24 2013, 10:42 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,602 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I have been wondering about this for awhile, as I have a fiberglass back pad core that I want to transplant the original vinyl and padding to. The trick with contact cement is to let it dry long enough. It doesn't work like glue in that the solvent has to flash off or it will never hold anything. With normal glues that happens after the parts are together. Another thing with contact cement is that once touched together the parts have a way of becoming pretty married to each other. You can pull things apart and reposition, but it often leads to hard feelings. Have fun (IMG:style_emoticons/default/bye1.gif) |
r3dplanet door panel construction May 23 2013, 08:51 PM
r3dplanet Well, I *think* the answer is contact cement. Yes,... May 23 2013, 11:54 PM
GeorgeRud When the panel is installed, the pressure from the... May 24 2013, 02:14 AM
wndsnd
When the panel is installed, the pressure from th... May 24 2013, 11:53 AM
nathansnathan I found that the stock staples are 4mm iirc. The o... May 24 2013, 08:29 AM
Harpo Mikey914 had posted that he only used glue. I used... May 24 2013, 09:52 AM
GeorgeRud Not as much as with the original backing, but shou... May 24 2013, 12:29 PM
Harpo Here are the binder clips that I used to hold the ... May 24 2013, 01:25 PM
rjames $25 for all materials per panel including a n... May 24 2013, 01:38 PM
Mikey914 The problem with just using a flat piece of fiberb... May 24 2013, 05:29 PM
nathansnathan
The problem with just using a flat piece of fiber... May 24 2013, 05:35 PM
rjames
The problem with just using a flat piece of fibe... May 24 2013, 06:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 AM |
