| r3dplanet |
May 23 2013, 08:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Peeps,
Allow me to begin by stating that I've never done this before. Well, not for twenty years anyway when I was an undergrad working in a furniture restoration shop as a college job. I bought one of Mikey914's cool new fiberglass door panel and vinyl kits as seen here: http://www.914world.com/bbs2/index.php?sho...10198&st=20 For additional reference: http://www.914world.com/bbs2/index.php?sho...=54608&st=0 Armed with this how-to, I'm off to work in an empty bedroom because it's Portland, WCR is three weeks away, and it's pouring rain outside. I admit I'm lost without a stapler. There are two things I don't know how to do. I have the aluminum strip riveted in and the bolster is nicely aligned with positive lock. But I don't know exactly how to attach the vinyl on the backside without a stapler. Sure there's contact cement, but it doesn't seem like that would work conveniently because you can't just inch your way along and keep the vinyl nice and and tight around the corners. Any ideas from those smarter than I? -marcus Attached image(s)
| Mikey914 |
May 24 2013, 05:29 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The problem with just using a flat piece of fiberboard is the top bolster. Just curious how you address that as there is a curve in it. Looks like you may have taken the top off the old panel and attached it somehow?
Thanks for putting this out there I've been too busy to even get mine done, but I'm going to have to as WCR isn't that far away. -Mark |
| nathansnathan |
May 24 2013, 05:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
The problem with just using a flat piece of fiberboard is the top bolster. Just curious how you address that as there is a curve in it. Looks like you may have taken the top off the old panel and attached it somehow? Thanks for putting this out there I've been too busy to even get mine done, but I'm going to have to as WCR isn't that far away. -Mark The early door panels, the top is actually metal, so the whole board part is flat. |
r3dplanet door panel construction May 23 2013, 08:51 PM
r3dplanet Well, I *think* the answer is contact cement. Yes,... May 23 2013, 11:54 PM
GeorgeRud When the panel is installed, the pressure from the... May 24 2013, 02:14 AM
wndsnd
When the panel is installed, the pressure from th... May 24 2013, 11:53 AM
nathansnathan I found that the stock staples are 4mm iirc. The o... May 24 2013, 08:29 AM
Harpo Mikey914 had posted that he only used glue. I used... May 24 2013, 09:52 AM
nathansnathan I have been wondering about this for awhile, as I ... May 24 2013, 10:03 AM
worn
I have been wondering about this for awhile, as I... May 24 2013, 10:42 AM
GeorgeRud Not as much as with the original backing, but shou... May 24 2013, 12:29 PM
Harpo Here are the binder clips that I used to hold the ... May 24 2013, 01:25 PM
rjames $25 for all materials per panel including a n... May 24 2013, 01:38 PM
rjames
The problem with just using a flat piece of fibe... May 24 2013, 06:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:43 AM |
